November 21, 2025, 10:39:28 PM *
Author Topic: little help needed on fork fluid capacity.  (Read 1322 times)
gregk
Retired
Chippewa Falls, wi.
« on: September 24, 2010, 12:07:24 PM »
2000 I/S overhauled forks, added fluid as described in Tech. manual, Buttt left fork ends up with about 22.5 oz. and the right one ends up being about 20 oz. Does this seem ok ? I put my hand over the extended tube & pushed down to purge out the air the book dont say to take the hand back off to extend the tube but that is what I done and then the hand over the tube & plunge more times. All air seems to be gone. Sucked out excessive fluid & I get 20 oz.
SCain
Rio Rancho, NM
« Reply #1 on: September 24, 2010, 02:58:49 PM »
Yes its OK, there is a different capacity between left and right for legs.
Steve
RP#62
Gilbert, AZ
« Reply #2 on: September 24, 2010, 06:45:47 PM »
The volume figure tells you how much to buy.  The dimension from the top tells you how much to put in.  The book can't tell you exactly how much to put in to achieve the dimension from the top - too many variables.
-RP
gregk
Retired
Chippewa Falls, wi.
« Reply #3 on: September 24, 2010, 07:46:55 PM »
 Thanks guys ! I'll wip it back togather Sunday if its done rainin and ck.her out maybe wed. I'll ride to Rapids or the next week on a warm day.
