November 21, 2025, 10:21:20 PM *
Author Topic: ok everybody were do i start ...  (Read 2031 times)
eric in md
« on: September 25, 2010, 10:55:36 PM »
99 i/s used daily  you know the the fast black one .. the  center dash didnt light up tonight on way home.. all dry for days what do i have to do to fix this? were do i start.   thanks for you help eric
Mr.BubblesVRCCDS0008
« Reply #1 on: September 26, 2010, 05:07:36 AM »
On an interstate the display not lighting up is a good sign the battery is getting very low. It is the first indicator that your gonna be on the side of the road soon. Check to make sure your alt. and main fuse are in good shape ,also cables are clean and tight on battery and  ground at back of block. If all this is good check fuses too.
eric in md
« Reply #2 on: September 26, 2010, 06:31:50 AM »
will do that thanks
Motorider
Pennsylvania
« Reply #3 on: September 26, 2010, 09:29:28 AM »
A friend of mine just went through this two weeks ago, with his I/S. It turned out to be his alternator.
eric in md
« Reply #4 on: September 26, 2010, 03:48:42 PM »
update .. it does have the forth alt. on it . rode 182 miles today .. no problems but was worried.. dash works fine during day time . at night has no back light on it . still looking thanks
Cattman
Franklin, IN
« Reply #5 on: September 26, 2010, 04:52:45 PM »
There are 4 bulbs on the back of the dash assembly. I've had 2 go out over the course of years. Remove speaker panels and then unbolt the dash. It will roll forward onto the top of the tank and you pull the rubber plugs out of the back. Bulbs are under them.
eric in md
« Reply #6 on: September 26, 2010, 05:02:04 PM »
thanks .. i have to check them out
« Reply #7 on: September 27, 2010, 04:42:12 PM »
Any idea of the bulb #? I think I have one out, so maybe just change them all if not too expensive.
RP#62
Gilbert, AZ
« Reply #8 on: September 27, 2010, 06:27:00 PM »
http://www.rattlebars.com/valkfaq/schematics/rpage12i.html
« Reply #9 on: September 28, 2010, 05:57:34 PM »
You can get the 74 bulbs at most auto parts stores. Do all four at one time so you don't have to go there again.
