November 21, 2025, 10:20:19 PM *
Author Topic: Did some PM's today on the Interstate  (Read 1569 times)
Thunderbolt
Worthington Springs FL.
« on: September 26, 2010, 05:02:36 PM »
I had not checked the splines since installing the car tire 2 years and 10,000 miles ago.  I removed the differential and drive shaft, checking and cleaning everything.  Thrust washer still good, changed all 3 o-rings, looks like the Belray waterproof grease is doing a good job, so used it again.  There are a lot of brackets and chrome things still off and in need of polishing yet but she will be good to go to Maggie Valley in a couple of weeks.
« Reply #1 on: September 26, 2010, 05:51:27 PM »
Splines look great Terry  cooldude  Did you pull the driveshaft out of the final drive ? That's what took my ridin' bud Greg's out a few weeks ago ( Dry pinion cup  Sad  )  along with a fried u-joint and splines...His was toast.
« Last Edit: September 26, 2010, 06:12:37 PM by Smokinjoe-VRCCDS#0005 » Logged
Thunderbolt
« Reply #2 on: September 26, 2010, 06:06:32 PM »
Cleaned the weep holes out and regreased the shaft both ends with Belray.  Tightened the 4 nuts on the shaft tube last.  Looks like we won't see y'all at the FCR.  I have to come back to work on the 15th.  We will be in Maggie Valley  Oct 9-14.
« Reply #3 on: September 26, 2010, 06:10:44 PM »
Maybe we could ride up to Maggie on saturday the 9th and do lunch ...Could take a ride up The Blue Ridge Parkway and loop back into Maggie after lunch.
Thunderbolt
« Reply #4 on: September 26, 2010, 06:29:39 PM »
Probably around 4 or so.  Sunday might be doable for lunch somewhere in the middle..........  We will probably have a couple of Harley buds with us.
« Reply #5 on: September 27, 2010, 10:45:58 AM »
Let me know  cooldude
