November 21, 2025, 10:20:23 PM *
Author Topic: Truck stack discolor  (Read 2040 times)
« on: September 28, 2010, 12:15:40 PM »
Any one else have their Airflows discolor? Mine has a hint of gold to it. Noticable when up close, esp against the oem heat shield, but from a distance it looks good.
Momz
ABATE, AMA, & MRF rep.
« Reply #1 on: September 28, 2010, 02:20:43 PM »
My Dragon "Packs & Stacks" have the same situation. I believe that the crome has just gotten hot and may be "blueing". I'm going to try a product called "Blue Away".
ALWAYS QUESTION AUTHORITY!
« Reply #2 on: September 28, 2010, 03:34:18 PM »
Let me know how it goes.  cooldude
ptgb
Youngstown, OH
« Reply #3 on: September 28, 2010, 04:23:56 PM »
Yep... Mine are yellowing. Drives me nuts. Mine are from Iowa 80 as Airflow was on backorder at the time.
+1 on wanting to know how the cleaners work on making them look better. Thanks
Michvalk
Remus, Mi
« Reply #4 on: September 28, 2010, 05:07:55 PM »
You guys aren't putting wax on the stacks are you? Even some chrome cleaners will put a yellow sheen on hot chrome if they are a cleaner/wax. If this is the case, any good chrome cleaner should remove the yellow cooldude
Bugslayer
Lubbock, Texas
« Reply #5 on: September 28, 2010, 05:50:49 PM »
I'm kinda surprised that there's enough heat back on the tip's to cause blueing.
« Reply #6 on: September 28, 2010, 06:20:50 PM »
only takes 180 degrees for wax/polish to dull
http://topoftheline.com/chnipo.html
LL
Flower Mound TEXAS!!!!!!
« Reply #7 on: September 29, 2010, 05:09:14 AM »
Not wiping down the exhaust after maintenance (grease of some form) can cause them to turn from what I am told.
VRCC #472
TearlessTom
Spanish Fort, AL.
« Reply #8 on: September 29, 2010, 06:51:17 AM »
I've had no problems with mine, they look awesome!
Challenger
« Reply #9 on: September 29, 2010, 06:32:24 PM »
Heat?  If they are running the full truck stack (IE) driven onto the muffler clear to the collector, they will get really hot. I have the airflows on the STD (21000 miles on them) and Iowa 80 stacks on the I/S (19000 miles) neither one are yellowing, I Use only turtle wax chrome polish to clean them. But I would bet that yours will clean up again.
bigdog99
1/1/2011 86,000 miles
Kouts Indiana
« Reply #10 on: September 29, 2010, 07:26:57 PM »
cleaned my turn downs with colonel brassy's, took a lot of the road crap off and put a shine back on... kind of expensive, but it doesnt take much.
VRCC#31391
VRCCDS0239
