February 01, 2026, 07:03:35 AM *
Author Topic: Galfer brake lines  (Read 2105 times)
shortleg
maryland
« on: October 04, 2010, 11:14:24 AM »
  Have a new set of Galfer brake lines for front and
rear.
  The front are madeup of four parts. Has anybody
used these and how did they work for you.
      Shortleg[Dave]
Bagger John - #3785
« Reply #1 on: October 04, 2010, 03:25:05 PM »
I'm getting ready to put a set on my Concours 14 and will probably do one or more of the Valkyries with them come next spring. Will let you know if I run into any snags - please do same.
« Reply #2 on: October 04, 2010, 06:38:07 PM »
I have both front and rear lines advice mount the lines and make sure that the bleeder at the triple tree is closed. My bleeder nipple was screwed all the way in and still wouldn't stop the flow of brake fluid. just make sure when its closed, its closed. The rear line will need to be rerouted and be prepared with a couple of wire ties to make the run over the swing arm to the rear caliper. Bleeding for the rear no problem just a bit tight but the front bleed the system from the calipers then do a final by opening the bleeder on the triple tree. Just seems to hold a really small amount of air.
http://www.directlineparts.com/byBrand.asp?brd=Galfer&str=2
« Last Edit: October 05, 2010, 06:23:01 PM by Robert » Logged
NITRO
Eau Claire, WI
« Reply #3 on: October 04, 2010, 07:17:04 PM »
Where did you get your lines?
When in doubt, ride.
Disco
Republic of Texas
« Reply #4 on: October 05, 2010, 05:07:05 AM »
Dave,
The fronts are a painless Remove & Replace.  Mine fit perfectly and I really like the fact that the OEM wire retainers can be reused on the Tee.  Ditto the rubber grommets in the fender retainers.
The rear was more of a chore.  I did mine at the same time I changed tires and serviced the final drive.  I would either wait to do the rear until you service the final drive, or better, use the brake line R&R as an excuse to service the final drive.  You'll have much more room to work with if the wheel/tire is out of the way.
NITRO,
I believe Galfer has a $250.00 minimum to order directly from them the first time, and they'll sell at list.  I bought mine through my local dealership where I get a discount off list.  They bought them through their Tucker Rocky account.
DFG
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
fordmano
San Jose, CA.
« Reply #5 on: October 06, 2010, 01:40:34 AM »
Just started on my MULTIPOINT swap out of items. ???
I just picked up a complete set front rear ane clutch lines off of EBay for $199.00 and it inlcuded a bottle of Galfer brake fluid. I will be taking pictures as I go. i just put my Valk up on jacks yesterday and I have only pulled the seat, tank and side covers as of yet.
During this project journey I will be, crazy2
1) Swaping out Front Brake lines for new galfer stainless lines
2) Swaping out rear Brake line with new Galfer Stainless line.
3) Swaping out Clutch line with new Galfer stainless line.
4) De-Smogging
5) Install Audiovox cruise control
6) Install rear Progressive 416's air shocks
7) install resivoir and compressor for added storage of onboard air for fill ups and in flight suspension adjustments.
8.) jetting my carbs.
9) installing my HID lighting.
10) Installing a couple more sets of LED's tail, stop and turn lights.
11) adding the under trunk rear fender stop light from a standard or tourer.
12) new front tire (Avon)
13) New rear tire (Avon)going back to a M/T for now tracking down some odd handling issues I am still having on my Interstate
14) new head bearings.
15)Install my new set of front Polk Audio speakers.
16) new attempt at installing the mini amps I picked up off of FleaBay
Pictures to come I will start a new thread for all of this if you would like to follow along
83GS550
93XR650L TARD!
97WR250
99ValkyrieI/S Tri-tone
01YZ125(x2)
05DRZ-125
« Reply #6 on: October 06, 2010, 09:44:29 AM »
Will await your postings, would also like to look at replacing the brake lines with steel.
papa bear
« Reply #7 on: October 07, 2010, 03:57:07 PM »
Got mine at www.cyclebrakes.com  You can order custom lengths if needed to fit with risers. Even though the standard honda lines will work with 6" Duece risers, the stock length steel lines will be short, so order as needed to fit. Also if you have put on the peg relo-kit from rattlebars you will need a couple of extra inches for the rear line.
Clutch line will also need extra length for risers.
