February 01, 2026, 08:32:57 AM *
Author Topic: Speedo and Odo not working  (Read 2308 times)
G-Man
White Plains, NY
« on: October 08, 2010, 08:28:18 AM »
Where should I look first.  Thinking a cable is disconnected somewhere.
« Reply #1 on: October 08, 2010, 08:40:17 AM »
my guess........."disconnected" right where its broken inside the housing......new cable is cheap, easy fix
« Reply #2 on: October 08, 2010, 08:54:17 AM »
First things first,,, STD / Tour or IS ???
« Reply #3 on: October 08, 2010, 08:57:40 AM »
HDL sells a stainless cable that would look cool I think........if mine breaks, thats what Id get
mirion
1997 Std - 2000 IS
Frankenmuth, Michigan
« Reply #4 on: October 08, 2010, 09:07:43 AM »
My speedo gear box output shaft broke at the wheel (not the cable) because I reassembled the wheel with the gearbox anti-rotate dog on the wrong side of the rotation, requires new gearbox to fix. Have you had the front wheel off lately?
G-Man
White Plains, NY
« Reply #5 on: October 08, 2010, 12:38:37 PM »
Standard, front wheel has not been off.
Needle stays at "0" mph and odometer and trip odometer not moving.  Stopped during the ride.
« Reply #6 on: October 09, 2010, 10:33:18 AM »
I think I paid $18 for a new cable, but that was a couple years ago
« Reply #7 on: October 09, 2010, 11:04:58 AM »
Yep, if its a STD or Tour then it may well be the cable.. If you raise the front and spin the front wheel you could tell the problem when the cable is removed,, does the drive work/spin?? If so, is inner cable free and does it spin easily?? Remove the upper end from speedo and see if the upper end spins while you spin the lower end..
laserpat
Cedar Park, Texas
« Reply #8 on: October 09, 2010, 11:16:39 PM »
easy fix. replaced my cable in the homda dealer parking lot in Rapid City SD in 5 minutes
G-Man
White Plains, NY
« Reply #9 on: October 11, 2010, 05:56:49 AM »
Great, thanks all!
« Reply #10 on: October 11, 2010, 03:20:59 PM »
Well, was it the cable.......inquiring minds want to know??   ???
PharmBoy
Lawton, Ok
« Reply #11 on: October 12, 2010, 02:25:03 PM »
This was a very timely post.  Had my tourer speedometer lay down and die, and I came right here for info to find this an almost new post.  I found a broken cable yesterday and eventually found a new one in OKC today about noon.  This is a great place for info.  Oh yes, the OEM part #'s are (44830-MAH-000 for the housing & cable combination) & (44831-MAH-000 for the cable only)...JTL
4th Infantry Tet Vet
99 Interstate
97 Bumble Bee
97 Red & White
