May 03, 2026, 01:27:02 AM *
Author Topic: Gone Mobile  (Read 1422 times)
Ghillie
Garland, TX
« on: October 10, 2010, 06:07:27 PM »
Finally fixed the throttle assembly after this summers earlier incident.
Not only had the cable frayed inside, the throttle tube had degraded seriously with pieces being broken off inside the switch housing. It looks as if someone used a lubricant that caused the plastic to start breaking down. Thanks to T-Roy for the donation of the stock grips with the throttle tube.
BTW does anyone have some Kury P-clamps to mount pegs to the engine guards, the right clamp had been ground off clear through one of the screw holes.
When the people fear government, there is tyranny. When government fears the people, there is liberty.
Valkpilot
What does the data say?
Corinth, Texas
« Reply #1 on: October 10, 2010, 06:10:19 PM »
Which part of the guard do you want to mount to?  The curvy part uses a 1 1/8" clamp.  The support bar under the headers is 1".
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
Ghillie
Garland, TX
« Reply #2 on: October 10, 2010, 07:48:22 PM »
i need the 1 1/8
Valkpilot
Corinth, Texas
« Reply #3 on: October 10, 2010, 08:04:45 PM »
i need the 1 1/8
I don't have any that size.
Here's what I use on mine: http://www.jcwhitney.com/chrome-plated-heavy-duty-3-piece-bolt-together-clamp/p2006236.jcwx?filterid=j3
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
Ghillie
Garland, TX
« Reply #4 on: October 10, 2010, 10:59:08 PM »
looks just like what i have on there
