February 01, 2026, 08:51:01 PM *
Author Topic: problem with a fuel petcock  (Read 4436 times)
blackcat
Nicholas Vore VRCC # 30301
Mounds, Arkansas
« on: October 11, 2010, 10:12:15 AM »
friday i was cruising on the interstate when the bike started acting like it was running out of fuel, i was only 48 miles into the tank so that wasn't it but when i hit reserve nothing happened, coasted to the side of the road gagging the throttle    when i let it come down to a idle it leveled out and ran fine again, that happened several more time so i would just clutch it and idle until it pick up more fuel
got it apart today and inspected the diaphram it looks ok, but i can only keep it open with constant vacuum, but it wont hold vacuum UNLESS i plug the weep hole,
if i plug the weep hole everything works just fine, what would happen if i run it like this until i get a repair kit
nick
______________________
03 Standard -Fast Black
00 Interstate - Red/Black
97 Tourstate - Yellow/Ivory
2010 Goldwing - Pearl Yellow
Mr.BubblesVRCCDS0008
« Reply #1 on: October 11, 2010, 11:11:12 AM »
I'ld run mine that way, until parts came in to fix it. About 3 years ago I had the same thing happen soI just made the vaccum valve into a manual valve by removing the diaphram and replacing it with a heavy piece of gasket material. Now I just shut it off when I shutdown the bike.
Valkpilot
What does the data say?
Corinth, Texas
« Reply #2 on: October 11, 2010, 11:17:27 AM »
nick
It will work, just make sure you always turn the petcock to the off position when you don't have the engine running.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
blackcat
Mounds, Arkansas
« Reply #3 on: October 11, 2010, 12:48:05 PM »
i solved my problem for now, used a piece of vinyl tape in the center of the diaphram and put the plastic washer over that
nick
« Reply #4 on: October 11, 2010, 03:00:32 PM »
Once the OEM petcock starts its "swan song"  you can rebuild that, or jerry rig that but the bottom line is.....ITS A PIECE OF JUNK...GET RID OF IT  Get a Pingel and never look back.......or be ready for these headaches to return and return and return.....Been there done that
« Reply #5 on: October 11, 2010, 04:28:17 PM »
Yea what Chrisj said. Unless you like redoing things over all the time.  crazy2
fiddle mike
Nothing exceeds like excess.
Corpus Christi, TX
« Reply #6 on: October 11, 2010, 04:36:08 PM »
Odd that you should mention Pingle.  I signed on to ask a Pingle question and saw Nick's question.
It seems that my Pingle begins leaking  every two years. I like the unit but not the  down-time when it is rebuilt at the factory.  Do you know anything about it's innards?
Its the model make for metric Sportster, lever on the left.
Mildew
Live, Not Just Exist
Auburn, Ga
« Reply #7 on: October 11, 2010, 05:07:38 PM »
Mine acts up every now and then. I need to take my tank off tomarrow and see what's going on. My shutoff hasn't worked for many, many miles.
fiddle mike
Corpus Christi, TX
« Reply #8 on: October 11, 2010, 05:14:52 PM »
How about posting your findings?
I may pull my tank tomorrow but it will only be to inspect and see if I can tighten the fasteners any.
BigM
« Reply #9 on: October 12, 2010, 08:48:36 AM »
So your saying that the pingle give problems regulary also?
BigM
« Reply #10 on: October 12, 2010, 08:50:48 AM »
Also, will the pingle work with the chrome engine hangers?
« Reply #11 on: October 12, 2010, 08:54:38 AM »
I wouldn't even think of plugging the weep hole. Apparently there's something wrong with your petcock... if gas wants
to leak out the weep hole, and can't, it is probably going to leak down the vacuum line to #6... then you'll have
raw gas spewing out the exhaust, and maybe even end up with hydrolock...
AussieValk
Gold Coast, Australia
« Reply #12 on: October 12, 2010, 08:55:50 AM »
No it won't, but I just cut my engine hanger cover with a cut off wheel, filed down the rough edges, and all is good. You get used to reaching in and turning the thing on and off with one finger.
fiddle mike
Corpus Christi, TX
« Reply #13 on: October 12, 2010, 10:27:36 AM »
I  had to have it re-built two yrs ago.  Before that, it was longer than two years.  Since  Pingle has a system for returning for rebuild (which is inexpensive) you got to figure that the diaphragm wears, just as drive cushions or shock bushings do.
 I've never had an OEM petcock fail on any other Honda.
« Reply #14 on: October 12, 2010, 12:59:13 PM »
I assume you are talking about a vacumn pingle, the manual pingel should be fine.  Hope so, that's what I use.  Hoser
fiddle mike
Corpus Christi, TX
« Reply #15 on: October 12, 2010, 01:44:55 PM »
Affirmative.
I bought the vacuum model after experiencing hydrolock with the faulty OEM. I hadn't developed the habit of turning the fuel off after riding. If I was going to buy another, I'd buy what you are using.
« Reply #16 on: October 12, 2010, 02:03:07 PM »
I,m old enough to not have had Vacumn petcocks on bikes, when I stated riding,  Never did get out of the habit of turning it off.  Have forgotten to turn it on though, doesn't take long to notice that, a little embarassing when you slow to a stop a mile from home cause you have'nt quite woke up yet.  Cheesy  uglystupid2  Hoser
« Reply #17 on: October 12, 2010, 03:55:48 PM »
I'm also old enough to not have used the vac shut off. I converted my stock valve to a non vac model and just turn it off and on manually. I've been running this way for over 3yr and about 40 thousand miles with no problem. Yes if you forget to shut off you cold hydrolock but the same hold true for the pingle valve.
fiddle mike
Corpus Christi, TX
« Reply #18 on: October 12, 2010, 04:15:20 PM »
How did you convert the unit?
BigM
« Reply #19 on: October 13, 2010, 12:19:28 PM »
What is difference of petcock rebuild kit and cover set rebuilt kit some have reffered to.if any?
« Reply #20 on: October 13, 2010, 12:22:29 PM »
Ones a rebuild kit for the rebuild kit.  2funny
Ah just kidding, I believe they are both the same, just the way it is labled for ordering.
« Reply #21 on: October 14, 2010, 05:38:46 AM »
Mike, I took the stock one apart and replaced the diaphram  with a piece of thick gasket material. The shut off and res still work as they did before. JP (hard 6) has also done it by jb welding up the vac side where the vac hose hooks and the weep hole is and getting an o ring to seal between the two parts where the diaphram was. Hope this helps.   I was also gonna put an electric shutoff in the fuel line just haven't done it yet.
fiddle mike
Corpus Christi, TX
« Reply #22 on: October 14, 2010, 09:49:15 AM »
I've had the tank up on the bench, vacuum pulled and outlet seal off and let it sit like that for a couple hours.
 It seems the gas was leaking around the diaphragm box when I released the vacuum. I tightened the screws and repeated the test without getting a leak. I am cautiously optimistic.
What kind of shut-off are you looking at?
« Reply #23 on: October 15, 2010, 03:49:07 PM »
I had saved the website for the shutoff but computer died and lost all my good stuff. Several people are running an electic shutoff maybe some one will chime in.
3W-lonerider
Shippensburg Pa
« Reply #24 on: October 17, 2010, 04:50:08 AM »
http://www.dan-marc.com/79-afc11112.html
Mildew
Auburn, Ga
« Reply #25 on: February 20, 2011, 08:09:36 AM »
I got my tank off and the fuel was on the "on" position for the last 3 or 4 months. Ofcourse that really dosen't matter if the petcock is faulty anyhow right. No fuel spilled out anywhere when I took off the tank and it dosen't run through the petcock when I turn it on. It's the first time I had the tank off and don't have a clue what I'm doing but I'm going to order me a new kit this week or maybe make a gasket.
