February 01, 2026, 08:32:06 AM *
Author Topic: When re-lube splines  (Read 2069 times)
Spirited-6
Nicholasville, Ky.
« on: October 13, 2010, 08:37:26 AM »
do you need to replace all O rings , Washers, ect. I replaced all mine about 12,000 ago and plan on a re-lube over down time this winter. I give up on working "archives" for info. Embarrassed I must confress I`m not very good at Computers, so I ask for HELP.  Roll Eyes TIA
Don
Spirited-6
Redline +
Northwest Washington
« Reply #1 on: October 13, 2010, 09:55:27 AM »
I would. cooldude
Redline  Cool
donaldcc
Palm Desert, CA
« Reply #2 on: October 13, 2010, 10:06:19 AM »
  O rings are $2.50 each at HDL,
http://www.hdlparts.com/fiche_section_detail.asp?section=148750&category=MOTORCYCLES&make=HONDA&year=1997&fveh=3476
or your can get 5 sets of the 3 o rings from Carolina Bike and Trike for total of $12.99
http://www.carolinabikeandtrike.com/ORings.htm
Don
« Reply #3 on: October 13, 2010, 10:07:28 AM »
Yea their cheap. I havent replaced the thrust (plastic) washer in a few changes. It looked good still at the last one.
donaldcc
Palm Desert, CA
« Reply #4 on: October 13, 2010, 10:17:45 AM »
Thrust washer $4.26
http://www.hdlparts.com/fiche_select.asp?mfg=Honda&partnumber=42616-maj-g20
Don
Spirited-6
Nicholasville, Ky.
« Reply #5 on: October 13, 2010, 10:47:48 AM »
When I replaced all in 08 at Direct Line - four items were $11.57 shipped.  Boy, how things have changed. Roll Eyes I was just asking if it was a thing that had to be done with every spline lube @ 10-11 K. The OEM I pulled out at 13,400 miles looked good, as if I could tell. Roll Eyes
 Roll Eyes
Don.
Spirited-6
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #6 on: October 13, 2010, 11:55:47 AM »
i know alot are going to disagree, but when i take mine apart, if they look good, i just re-lube and put back in,  on one of my valks with 42000 miles i have only replaced the 3-rd o-ring.  everything is good.
vanagon40
Greenwood, IN
« Reply #7 on: October 13, 2010, 12:03:52 PM »
Unless one appears to be damaged, I do not believe it would be necessary to changed at every lube (especially if lubes are every 10,000 to 12,000 miles).  I just cleaned and reused mine on the first lube, and replaced on the second lube.
Spirited-6
Nicholasville, Ky.
« Reply #8 on: October 13, 2010, 01:16:56 PM »
This is what I was thinking, the ones I took out @ 13,400 looked as good as the new ones, that is if you could tell a bad one from a good one  Undecided
Don.
Spirited-6
« Reply #9 on: October 13, 2010, 02:57:59 PM »
I reused a set once. I can tell it felt tighter after putting new ones in.
