February 01, 2026, 09:58:27 AM *
Author Topic: Just got done with Galpher lines  (Read 1684 times)
shortleg
maryland
« on: October 17, 2010, 12:28:53 PM »
Just replaced front brake lines with Galpher lines.
Was not bad at all. Galpher setup is in four parts.
Just replace a piece at a time and you are done.
 Used Miti vac to bleed brakes. Only used about
3/4 of a can to bleed them. One more thing I
found was I needed to get two small nuts and
bolts to mount the cross section under the triple tree.
  So if you are thinking of doing it, Go ahead it,s not that hard.
             Shortleg[Dave]
NITRO
Eau Claire, WI
« Reply #1 on: October 17, 2010, 06:56:45 PM »
This is something I want to do this winter, I'm interested to see if you notice a difference. Any advice on where to get the lines?
When in doubt, ride.
shortleg
maryland
« Reply #2 on: October 18, 2010, 04:04:39 AM »
     I did notice that the reaction and feel are better.
  Got them from direct line.
    Was easy to do and only took a couple of hours, thats
with bleeding and all
               Shortleg[Dave]
