September 12, 2025, 12:40:11 AM *
Author Topic: Leaning Big Time  (Read 816 times)
abcdleines
« on: October 18, 2010, 12:48:57 PM »
Have looked a pics of other I/S and mine seems to lean a lot more than the ones in the pics. Is there an after market kick stand or an adapter I can buy for the one on the bike now? Thanks
Joe Hummer
Arnold, MO
« Reply #1 on: October 18, 2010, 12:53:37 PM »
Take a look under your bike and make sure that the kick stand bracket isn't bent/broken.  If it is leaning over that much more, chances are there is damage.
Just thought of another possibility...has your suspension been changed?
Joe
1999 Valkyrie Interstate
New Haven, Indiana
« Reply #2 on: October 18, 2010, 03:50:21 PM »
It would lean over farther only if the suspension was raised.  Might be damaged or loose.
Mr.BubblesVRCCDS0008
« Reply #3 on: October 18, 2010, 06:33:22 PM »
You can place a washer or two between the frame and the left side of the backet to lessen the lean some. A little bit will change the angle quite a bit.
FLAVALK
Winter Springs, Florida
« Reply #4 on: October 18, 2010, 06:42:18 PM »
Joe
Agreed. I've seen damage to the cross member (bent) to which the KS is bolted that results in this situation. Not sure this is the problem but it's worth a look
