February 01, 2026, 10:00:32 AM *
Author Topic: Turn signal relay  (Read 7345 times)
skromfols
You only go around once
Valley Springs, Calif
« on: October 21, 2010, 05:29:33 PM »
I occasionally forget to cancel my turn signals, which can be very dangerous.  On my Triumph America I found an aftermarket relay that you can adjust to turn off after 60 seconds or so.  It was a very easy install, just unplug the Triumph relay and plug in the aftermarket relay.
Does anyone know if there's such a relay available for the Valkyrie?  I would certainly be interested in one if it was available.
Stan
« Reply #1 on: October 21, 2010, 08:15:30 PM »
Probally be in a worse boat if they shut off before you turnt.  Undecided
OverdueBill
Elkmont, Alabama
« Reply #2 on: October 21, 2010, 10:32:54 PM »
My 1985 Honda v65 has self cancelling signals.  I wonder if the smarter folks here could figure out what parts would be needed from it to make our valks self cancel?  Fudgie, "turnt".  I think you can speak southern!
Mr. Nuts
Bitterroot Valley Montana
« Reply #3 on: October 21, 2010, 10:52:58 PM »
I use a Kisan SignalMinder and a loud buzzer (Radio Shack) I have mounted under my tank. My system cancels the signal light after a period of time and it also has a loud signal while the lights are flashing. When the lights are canceled the tone on my buzzer changes pitch reminding me to cancel the signal switch by pushing it inwards once. If I'm a long time at a light the signal cancels and I can hear the pitch change which reminds me to activate the signals again.
I like the system I have and would have a hard time rmembering without it. I followed a bike today for miles with his signal flashing and was grateful that doesn't happen to me.
https://www.kisantech.com/index.php?cat_id=4
“Speed has never killed anyone.... Suddenly becoming stationary, thats what gets you.” - Jeremy Clarkson
« Reply #4 on: October 22, 2010, 08:06:24 AM »
I'm bilingual!  Cheesy
skromfols
« Reply #5 on: October 22, 2010, 08:20:41 AM »
The signal minder is exactly what I was looking for.  I'll just have to check to see where the relay is located on my Valk and make sure I get the right replacement relay.  I also had a V-65 Magna (1984) which had self cancelling turn signals and a gear indication light.  Neither are critical but both would be very convenient.
Stan
paps350
Pittsburgh Pa
« Reply #6 on: October 22, 2010, 10:56:55 AM »
I replaced my older model Kisan signalminder with a new improved model that can be set to blink the signals a predetermined time but will stop the timer as long as the brakes are applied so sitting at a redlight it will not time out and turn the signals off. Mine is set for 30 seconds which I think that is the longest setting.
joefromperry
Perry, OH
« Reply #7 on: October 23, 2010, 08:19:44 PM »
+1 on the Kisan SignalMinder. I've been using it on my Interstate for years now and am very happy. I also have the turn signals as running lights and plugged in their VectraLights which are attached to my mirrors. I'm told they are very visible. Good product(s) from a good company.
2000 Honda Valkyrie Interstate Silver/Blue
2002 Honda Shadow ACE Deluxe
1972 Honda CL350K4 Scrambler
2008 Ural Patrol
1987 Honda Rebel 450
