February 01, 2026, 10:00:35 AM *
Author Topic: AIR Cleaner  (Read 2353 times)
NW roller
Dunkirk MD
« on: October 22, 2010, 04:53:50 PM »
Going to replace  Air filrter this weekend. I have the book and I am some what mech inclined. Any thing I should know ? 1999 IS police
Those who won't listen must feel.   David B
Joe Hummer
Arnold, MO
« Reply #1 on: October 22, 2010, 04:59:46 PM »
Nope it is fairly easy. You will have to take the seat off and remove the tank.  Make sure you turn the petcock off before removing the line.  you will also have to remove the petcock handle. On the IS, you also have the fuel sensor wires to disconnect.  Go slow and remember where things go and you will be fine.
1999 Valkyrie Interstate
Pete
« Reply #2 on: October 22, 2010, 05:28:42 PM »
When you pull the gas line off have some paper towels to catch a small amount of gas from the line.
Needle nose pliers will help remove and re-attach the lines.
There is a phillips screw that has to be loosened  inside the petcock handle.
A small piece of lumber to place under the rear of the tank will help with space as you re-attach the hoses.
Have fun
« Reply #3 on: October 22, 2010, 07:26:03 PM »
Carefull with the air box gasket, unless its a K&N.
Thunderbolt
Worthington Springs FL.
« Reply #4 on: October 23, 2010, 05:07:27 AM »
one extra thing I do is take out the one small 8mm bolt that holds the petcock lever on the framework of the bike.  Once you remove this bolt, the whole assembly can be removed and this gives you a lot more room to get to the petcock hoses etc.
Relax
Power & elegance...just like the Valk
Oslo, Norway
« Reply #5 on: October 24, 2010, 12:57:40 PM »
Do you need to take the hoses off, or is it possible to lift the tank enough to replace the air filter ?
 ( one guy holding the tank, while you replace the filter )
Joe Hummer
Arnold, MO
« Reply #6 on: October 24, 2010, 01:11:32 PM »
You do not have enough slack in the lines to get the tank high enough to get the screws out of the air box.  Tank needs to come off for this job.
Joe
Spirited-6
Nicholasville, Ky.
« Reply #7 on: October 25, 2010, 06:27:21 AM »
This was posted some time back about , " son helt tank up from front while I replaced filter"
I`m with Joe on this. I don`t see how that is possible, but then again I`ve never tried it. Undecided
Spirited-6
