February 01, 2026, 10:00:39 AM *
Author Topic: Metzler tire question???  (Read 2637 times)
F6CTrider
Denver, Colorado
« on: October 24, 2010, 04:48:18 PM »
I am shopping to replace my front tire.  My old Metz ME880 gave me 16K but is quite bald.
(I shouldn't have ridden it today, but the weather was dry and gorgeous!)
I am looking to replace it with another ME880.
Jake Wilson has two listed ????
150/80R-17 (72V)   for $165.99  and
150/80-17 (72H)  for 115.99
I thought that ALL ME880 were radial.  But the "R" has me wondering.
Any thoughts??
Riding a GATT 205/60-16 on the back, also 16K and looking great.
(yes splines have been lubed, twice actually)
Thunderbolt
Worthington Springs FL.
« Reply #1 on: October 24, 2010, 05:14:57 PM »
Do a search for the tire specs.
« Reply #2 on: October 24, 2010, 05:48:42 PM »
Just curious, what pressure are you putting in that front Metz? I've put over 16k on mine in the past and weren't bald at that mileage. I used 40 psi in the front, usually 36-37 in my CT in back.
F6CTrider
Denver, Colorado
« Reply #3 on: October 24, 2010, 06:53:50 PM »
Well even the Metzler site does not define the difference.  I am guessing that the price difference and the "R" means that one is a radial and the other is a bias.
As for mileage, psi, etc.
I have been running 40-42 up front and rear both.
I am larger than most, have a rider about 1/3 of the time, and I ride the canyon twisties all / most of the time.  I thought 15-16K was doing good?  My boot heels are due for new rubber also!
« Reply #4 on: October 24, 2010, 07:05:34 PM »
15,000 to 16,000 miles is outstanding in my book I've never got over 11,500 ....My bikes never leave the garage without checking the psi....I run 42 in the front.
Challenger
« Reply #5 on: October 24, 2010, 07:14:54 PM »
All ME-880 Metz are not radials, the R does indeed mean radial, but there are a lot of Harleys out there on ME-880's and are not radial. Also check the speed rating on the bias, usually not as high.
« Last Edit: October 24, 2010, 07:16:47 PM by Challenger » Logged
« Reply #6 on: October 24, 2010, 08:30:47 PM »
You want the "R".
I have two bikes, and I order two at a time, so there's always a new one hanging on the wall.
RonW
Newport Beach
« Reply #7 on: October 25, 2010, 05:00:05 AM »
I have a related question. 40-lbs in my front Metzeler(R) caused the light bulbs in the front signals to dislodge out of their sockets. Lower it to 38-lbs and this hasn't been a problem. Has anybody else also experienced this? [2000 Tourer]
2000 Valkyrie Tourer
« Reply #8 on: October 25, 2010, 06:48:40 AM »
I have used a dunlop D404 bias on front and E3 radial on rear with good results, I plan to use a E3 bias with the d404 next It is the american elite used on the screamin eagle Harleys. 180/65/16. Hoser
« Reply #9 on: October 25, 2010, 07:20:09 AM »
I've had Metz since 2001. 4-5 rears and 3 fronts. Love them. Never a problem. My fronts go about 23k before they wore out, 40 psi.
Spirited-6
Nicholasville, Ky.
« Reply #10 on: October 25, 2010, 09:35:56 AM »
I`ve had 880`s on for about 12,000 and I think another 6 to 8 on front and maybe another 5 on rear. Running 40 & 41. I will replace with Metz.  Wink
Spirited-6
« Reply #11 on: October 25, 2010, 11:00:45 AM »
I'm running a Dunlop E-II bias (K491) on the front.  Has over 12k miles and measures at 8.5/32 tread depth.  At this rate it will exceed 50,000 miles. Handling is excellent with a radial rear (Cobra). I've practically eliminated front tire cost. The K491 was discontinued and replaced by the D404 with a nearly identical pattern and slightly less tread depth. I'd look into putting a bias rear on the front if I were you.  Or even if I weren't.
Mr.BubblesVRCCDS0008
« Reply #12 on: October 26, 2010, 05:09:31 PM »
The radial tire also has a higher speed rating the V rating is much higher  than a H rated tire.
