February 01, 2026, 11:34:53 AM *
Author Topic: metal adhesive  (Read 1840 times)
recall
Bournemouth Dorset United Kingdom
« on: October 25, 2010, 05:20:15 AM »
Hi All,
        I have my own thoughts.. but if any of you has a tried and tested method..as to what sort of metal adhesive would be best to use..I'm replacing my shift peg on the gear lever.. so as an added precaution I would like to add an adhesive as well, because of the pounding it will get .. I have ground my old peg of.. drilled the hole.. cant make up my mind what adhesive to use.. at the moment the peg has a long grub screw.. thinking about a lock nut or replacing the grub screw for a bolt with a lock washer and adhesive.. recommendations please ..recall
What you see is what you get...
vanagon40
Greenwood, IN
« Reply #1 on: October 25, 2010, 06:56:00 AM »
I know this does not exactly answer the question you asked, but I tapped threads into the shifter and then used a lock nut.
Procedure is explained here with photos:
http://bigbf.com/bigbf_shop/shift_peg/
Baloo
Rimouski, Canada
« Reply #2 on: October 25, 2010, 07:00:01 AM »
Loctite has a thread locking compound that is permanent. You cannot remove a bolt that had it on the threads without heating it. Might be what you're looking for...
Never ride any faster than your guardian angel can fly...
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #3 on: October 25, 2010, 08:46:42 AM »
don't put adhesive on it...if you ever want to change out pegs, it's just a whole lot of trouble.  i just drilled the hole after using a centering punch, put the bolt through, and used a thin stainless washer.  i put a dab of blue medium strength locktite on the threades, and used a stainless cap nut.
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #4 on: October 25, 2010, 08:55:03 AM »
hey recall... did you get those washers out of those shocks?, and readjust those tree bearings?  please post, we are all anchous to here.
Hoghead
Kilgore, TX
« Reply #5 on: October 25, 2010, 09:30:53 AM »
I have always used a medium grade Loctite and a nut with a nylon insert. Works better than a lock washer.
2000 I/S. Coronado Blue & Silver
1984 V65 Magna. Really Fast Black
E. Texas Patriot Guard Rider
