February 01, 2026, 09:59:01 AM *
Author Topic: Risers/Cables  (Read 2130 times)
Chiefy
Sarasota, Florida
« on: October 27, 2010, 07:32:45 PM »
I'd like to add some rise to my bars.  How tall (up-in) can I put on without having to worry about replacing or re-routing cables?  I would also like to move the tach and speedo to the bar.  Would they work as is on a stock bar?  How much rise would the speedo and tach accept if on the bars?
Thanks.
SANDMAN5
Mileage 65875
East TN
« Reply #1 on: October 28, 2010, 04:27:36 AM »
I think my risers are 4 up and 1 back. No problem with the cables.
« Reply #2 on: October 28, 2010, 05:31:59 AM »
These are as much movement as you can get with no cable changes or rerouting. (Just turn the cable clips on the handlebars around 180*
1st     http://www.hondadirectlineofshadyside.com/stores/product.asp?pid=519&str=2&ID=161485659
2d      http://www.hondadirectlineofshadyside.com/stores/product.asp?pid=468&str=2&ID=161485659
No idea on the tach/speedo move.
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #3 on: October 28, 2010, 06:05:20 AM »
ther is another place to check...daryl at xf6-custom.  he has a set of 4-inch polished risers...they are straight, but believe me they make the ride and handling alot more comfortable, and stable feeling.  i'm only 5'8-5'9 (short), and they feel good.
ricoman
Sarasota, FL
« Reply #4 on: October 28, 2010, 08:39:28 AM »
I have 6" risers on the new Valk. At first I didn't like them but have gotten used to them and enjoy. The prev. owner re-routed the cables and all works well.
The height did block the speedo & tach so I raised them both and brought them up and back, not onto the bars though (not the look for me), by fabricating a new bracket to mount them on using the original mounting holes on the top triple tree.
Try the site goose suggested, they have the stuff to move the speedo/tach to the bars.
« Reply #5 on: October 28, 2010, 10:21:50 AM »
Alot of people have put on Harley Deuce risers and still used the stock cables with no problems.......
http://www.timskelton.com/valkyrie/how_to/risers.htm
Farther
Quimper Peninsula, WA
« Reply #6 on: October 28, 2010, 11:18:45 AM »
I have these and had not problems with the cables.  Any greater rise and the throttle cables would probably bind.
http://cgi.ebay.com/ebaymotors/Honda-Shadow-Sabre-VTX-1100-VTX1100-Handlebar-Risers-_W0QQcmdZViewItemQQhashZitem2eb0dda611QQitemZ200535811601QQptZMotorcyclesQ5fPartsQ5fAccessories
~Farther
kickstand
allen park mi 48101
« Reply #7 on: October 28, 2010, 12:06:07 PM »
I have a used set of LAM-001 from HDL if interested send pm
ALLEN PARK ,MI
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #8 on: October 28, 2010, 06:03:00 PM »
chiefy....that's why i told you to go to daryl. with those 4 inch risers the handlebars will be in a place where you will really like. and you won't have any issues with the throttle cables.  he also makes a relocation kit that enables you to mount your stock gauges onto your handlebars, and carries the cables for your gauges when they are relocated.  it's like a kit form when you get all the parts together,  and it fits with with no problems.   Smiley
Chiefy
Sarasota, Florida
« Reply #9 on: October 28, 2010, 06:43:22 PM »
Thanks for all the suggestions!
