Jess Tolbirt
« on: October 30, 2010, 10:54:15 PM » |
I know should be on tech board,,,but,,, my bike runs like new except at wide open throttle,,,i can back off just a tad and zoom we are off to the races,,,punched baffles is all thats been done as far as i know,,,any ideas?
one other thing,,,on cold days my signals are very slow to react,,,i can turn on my turn signal and it wont start to flash for about 15 seconds,,,above 60 degrees and its just fine,,,any ideas?
thanks in advance for any replies...
Jack B
« Reply #1 on: October 31, 2010, 04:19:16 AM » |
You have a little moisture in the housing so you need to clean out the old grease in your turn signal housing and replace with some new. Then it will work like new..
Let’s RIDE
« Reply #2 on: October 31, 2010, 04:45:12 AM » |
Rejet the carbs and get a new flasher.
« Reply #3 on: October 31, 2010, 05:17:28 AM » |
Are you sure you're not up against the rev limiter at WFO? Runs really crappy, then.  hoser
Jeff K
« Reply #4 on: October 31, 2010, 05:50:52 AM » |
If this were posted on the tech board Id say The symptom you describe would indicate a lean condition. But since its not. I won't.
bogator
IN GOD WE TRUST------KK4KSN-------
Valley,Al
« Reply #5 on: October 31, 2010, 06:02:37 AM » |
Blinker fluid low, --------let it warm up to 60 degrees---
old grouch
Colorado Springs, CO
« Reply #6 on: October 31, 2010, 06:46:13 AM » |
Jess I have the same problem with "full throttle" on my 99 I/S. I am going to post on the Tech board (again) & see if someone has any help for us. Last time it sort of got blown off. Stan
 Don't float thru life, MAKE WAVES! 09/11/01 NEVER FORGET!
« Reply #7 on: October 31, 2010, 06:49:58 AM » |
Sounds lean, but I won't say anything if you don't.
Wrong board.
As Forrest Gump would say: “That's all I have to say about that.”
Jess Tolbirt
« Reply #8 on: October 31, 2010, 06:54:41 AM » |
thanks guys,,the grease thing sounds like that just might be the problem,,, now i will go over to the tech board and see if someone can tell me how to richen up a tad bit,,,
« Reply #9 on: October 31, 2010, 07:08:59 AM » |
The turn switch just needs to be cleaned. Mine does this around 40 degrees, esp turning left. sometimes it took 30 seconds. I cleaned mine up and added grease and worked smooth. Did it a few times this fall but I just turned them on sooner.
« Reply #10 on: October 31, 2010, 08:37:37 AM » |
If you read the website for the Pingel it says something like "stop letting your petcock be the high speed jets. Meaning: the OEM petcock will not deliver enough fuel at WOT if ANYTHING at all is hampering its performance. If it is reduced flow for a vacuum leak or something you will feel fuel starvation at high rpms and /or 5-10 minutes at 60 or 70mph where the float bowls are not filling fast enough.
Dogg
« Reply #11 on: October 31, 2010, 09:33:55 AM » |
I changed my petcock to a pingle for that very reason. not enough fuel flow for the carbs at wot. plus, you may have a vacuum leak causing this problem. that, creates a lean condition.
Jess Tolbirt
« Reply #12 on: October 31, 2010, 12:18:50 PM » |
it seems to me if it were the pet rooster i would be able to run wide open for at least a 1/2 mile before it starts to starve,,,i can run 60mph in high gear and go wide open and it immediately runs lean,,,back off just a tad bit and zoom,,,,,so i am thinking i will drill out my main jets a couple thousandths and see what happens,,,
« Reply #13 on: October 31, 2010, 01:02:52 PM » |
K and N filter without the prefilter might make it run lean. You didn't mention.
Drilling out the jets might help but what caused it to begin with?
Just my .02
Jess Tolbirt
« Reply #14 on: November 03, 2010, 07:43:42 PM » |
i modded the exhaust a tad bit but i wouldnt think that would have caused it,, i never went wide open before so it could have been this way for years,,,
Dogg
« Reply #15 on: November 03, 2010, 07:52:55 PM » |
your petcock will actually hold back the fuel pressure if you are wot. especially with an exhaust mod. might want to consider upsiZing low speed jets...
Jess Tolbirt
« Reply #16 on: November 03, 2010, 08:02:55 PM » |
o yea i fergot, i added the cruise control and also desmogged,,, my memory sucks sometimes,,,
