July 21, 2025, 03:00:29 PM *
Author Topic: Radiator fluid drip  (Read 1076 times)
bassin
Arkansas
« on: October 31, 2010, 02:31:14 PM »
Ok let me see if I can explain this, I recently heard what I would describe as a faint metal rattle coming from the area behind the radiator. I have not located the source, but after a ride today I got the flashlight and looking in between the carbs, toward the front of the engine I spotted a drip of radiator fluid. Just one small drop but with time I’m sure would get larger. My question can anyone give me a clue as to where or what may have cause the drip.
Thunderbolt
Worthington Springs FL.
« Reply #1 on: October 31, 2010, 04:18:58 PM »
at the thermostat housing, where the hose attaches to the housing.  I understand that if you can move the radiator out a little, it gives you more room to get to the clamp.  No personal experience with this, just read it on the boards several times.
SCain
Rio Rancho, NM
« Reply #2 on: November 01, 2010, 07:49:36 AM »
I have read about the upper radiator hose clamp just needs to be tightened a bit, as far as the noise you are hearing, check this.
http://www.valkyrieriders.com/shoptalk/buzz.htm
Steve
bassin
Arkansas
« Reply #3 on: November 02, 2010, 01:31:27 AM »
Thanks for the help the hose clamp was loose and the noise was coming from the radiator mounts which were loose, ready to ride.
