February 01, 2026, 01:10:18 PM
is it antifreeze????????
Topic: is it antifreeze???????? (Read 1870 times)
bg
Cumming, Ga
November 09, 2010, 01:08:41 PM »
just got back from a weekend trip and on the top of the engine on the right hand side i noticed a dried whitish with a slight green tint substance.
i see nothing dripping, have noticed no noticible odor wondering what it might be.
i've cleaned it off and will go for a ride tomorrow to see if it returns.
anyone else have this issue?
GOOSE
D.S. #: 1643
Southwest Virginia
Re: is it antifreeze????????
November 09, 2010, 02:11:58 PM »
bg....sounds like the clamp on the hose to the thermostat is loose.
bg
Cumming, Ga
November 10, 2010, 02:03:01 AM »
thanks, i'm off to check it out.
9Ball
November 10, 2010, 04:36:24 AM »
unless you changed your coolant type, then the greenish tint is a clue that it's a leak w/antifreeze in it.
Snugging the hose clamp is the first step....don't gorilla-torque it though.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
bg
Cumming, Ga
November 10, 2010, 01:49:11 PM »
the overflow hose on top looks fine. i can see a much larger radiator hose on the back side of the radiator when i look through the pod that looks really suspect.
the screw to tighten the clamp is facing away from me and pointing downward.
after 10 years it looks like i need a new hose.
is it easily changed or a job for the service dept?
normally when i pick up a wrench my friends all say "stop, drop the wrench and slowly step away from the bike".
9Ball
November 11, 2010, 04:11:04 AM »
since no one else piped in yet, you should be able to just try tightening the clamp. I haven't had the pleasure to have to do this yet, but from what I remember some have had to loosen the radiator and swing it out a little to get a flexible extension on this clamp. On the I/S, this most likely involves removing the pods as a minimum to access the radiator mounts.
Basic hand tools, creativity, and patience and should not involve an expensive trip to the dealer.
Hopefully others with first-hand experience will chime in. Good luck and make sure you let us know how it works out.
1999 Standard
2007 Rocket 3
2005 VTX 1300S
bg
Cumming, Ga
Reply #6 on:
November 11, 2010, 03:18:28 PM »
i loosened the pod and was able to get a revolution or two on the clamp.
took it for a short ride around the sub and didn't see any leak.
i'll check it again tomorrow with a longer ride.
sure hope this takes care of the problem.
thanks
