February 01, 2026, 11:34:45 AM *
Author Topic: wiring Stebel Nautilus horn  (Read 2333 times)
Hef
Opdyke, IL 62872
« on: November 12, 2010, 11:47:53 AM »
I purchased a Stebel compact horn and I want to use it with the Valk horn button. I am removing the original horn and replacing it with the Stebel. Will I need to wire in a relay and if so what is the a good relay to buy? Also what amperage for the relay? I am not very electrical savy so any help will be greatly appreciated. If a wiring diagram is available that would be nice too. Thanks in advance. Hef
« Reply #1 on: November 12, 2010, 01:17:39 PM »
go to rattlebars.com. Chet has electrical wiring there and how relays work.
9Ball
« Reply #2 on: November 12, 2010, 02:13:20 PM »
you definitely need a relay, the stock horn wires can be the trigger for the relay.  The Stebel draws about 18  amps, so you need a 20 amp fuse in the power supply wire from the battery to the relay.
Chet's diagram is about as clear as you will find.
A 40 amp relay can be bought at most auto parts chain stores.  Look in the electrical or fog light sections and you will see what you need.
Good luck, it's easy.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
bassman
« Reply #3 on: November 12, 2010, 02:39:27 PM »
M'be something here will help - thanks to Chet at Rattlebars  cooldude
http://www.rattlebars.com/valkfaq/circuits.html
ILcruiser
Crystal Lake, IL
« Reply #4 on: November 12, 2010, 05:45:27 PM »
Eastern Beaver sells a horn wiring kit which works great with a Stebel.  The kit contains all the wiring in a loom, plus an inline fuse and relay.  So it's really plug and play.  You have the option of keeping the stock horn, which I did, or removing it and wiring only the Stebel to the stock horn button.  The website has installation instructions.
http://www.easternbeaver.com/Main/Products/Horn_Kits/horn_kits.html
1999 Valkyrie Standard
Walküre
Nothing beats a 6-pack!
Oxford, Indiana
« Reply #5 on: November 13, 2010, 09:06:36 AM »
Very, very simple! You mention stock location? That's where I put mine. I took the stock wires from the stock horn, hooked them to the coil on my relay, ran a single 10 ga. wire with a 20 amp inline fuse back to the battery for power to the relay, and a 10 ga. wire from the relay to the horn. Then took another #10 wire, to a ground, for the ground to the horn. MAKE SURE you connect + to +, and - to - on the horn - a little hard to see on the casing or the horn, and not obvious.
I had to make a different bar, than the stock stacked set - it wasn't strong enough. So grabbed a piece of stainless, and polished it. Also had to make an aluminum stand-off, which I polished also.
I'd use at least a 20 am relay, but I had a 30, and that's great - the horn draws 18, if I recall. The stock wires are NOT big enough to handle the current draw. I hid the relay up by the horn, under the frame cover.
Here's a pic - better would be black wire, but red was in my box:
« Last Edit: November 13, 2010, 09:09:32 AM by Walküre » Logged
2000 Valkyrie Standard
1999 Valkyrie Interstate
2000 HD Dyna Wide Glide FXDWG
Roger Phillips
Oxford, IN
VRCC #31978
Yeah, what she said...
Hef
Opdyke, IL 62872
« Reply #6 on: November 15, 2010, 07:31:58 AM »
Thanks to all who replied. Got it hooked up this past weekend. It is LOUD!
