February 01, 2026, 11:34:54 AM *
Author Topic: Anybody tried to run a 205/70/16 on the back???  (Read 1658 times)
Tropic traveler
Silver Springs, Florida
« on: November 13, 2010, 06:40:13 AM »
In my never ending curiosity I must ask.
Seems that if a 205/65 fits a Valk (they do), maybe a 205/70 which is readily available could fit as well. It would be great to have the extra circumference/height of that tire on a Valk to shave off a few RPM at cruising speeds.
Anybody tried that yet??? ???
« Last Edit: November 13, 2010, 08:29:49 AM by Tropic traveler » Logged
'13 F6B red for Kim
X Ring
VRCC #27389, VRCCDS #204
« Reply #1 on: November 13, 2010, 09:10:30 AM »
I think you're going to have a problem with it.  It's taller than stock and you're probably going to have clearance problems with the fender.  I'm running a Toyo Proxes TPT in 205/65-16 on Sandman and it has an approximate 25.5" diameter.  The size you want is about 27.5" in diameter.  That's another 2"  Some guys have had to hammer the wiring harness guides down to gain clearance with their DarkSide tires.  Imho, that's not even going to help you to run that size.
Marty
