February 01, 2026, 11:34:56 AM
Starter switch rebuild
Topic: Starter switch rebuild (Read 1575 times)
Farther
Quimper Peninsula, WA
November 14, 2010, 03:07:38 PM »
I went for an invigurating 46 degree ride in between the rain storms here in the State of Jefferson and after refueling my starter switch started to hesitate and took two to three times in hitting it to get it to turn over without disengaging. I presume the starter switch needs some TLC. I seem to remember a thread on this subject. Can anybody point me in the right direction.
~Farther
Bone
Re: Starter switch rebuild
November 14, 2010, 03:56:09 PM »
Top of this page click on Shoptalk, then Starter Button.
November 14, 2010, 03:57:07 PM »
I would also highly recommend the relay installation covered farther down in the write-up. It substantially will cut the amps passing through that switch, the main cause of it going south on you.
http://www.rattlebars.com/mtz/starter.html
Bugslayer
Lubbock, Texas
November 14, 2010, 03:59:20 PM »
There's a section in Shop Talk that goes into servicing the switch.
http://www.valkyrieriders.com/shoptalk/VSGPages/starterbutton.htm
