The Clear Alteratives tailight LED array will not work with the OEM turnsignals; you must use LED front signals, and remove the rear, as they are integral to the tailight array.
To make it work you must use the supplied relay. And the turn signals wil not function until you add two diodes to the turn signal leads to the indicator lamp within the headlight; and the other lead from the indicator must be grounded.
Did you check all the connections? The terminal that has the white and black leads that plug into the digital relay is quite cheesy.
NOTE: front smal LED (bright) on lower triple clamp
NOTE: lack of rear OEM turnsignals and plate lamp
