February 01, 2026, 02:38:08 PM *
Author Topic: advance trigger wheel  (Read 1944 times)
Buda
Buda IL
« on: November 19, 2010, 06:13:16 PM »
I read about the 4 and 6* advance trigger wheel here.  Was wondering witch one would you guys recomend and where are you buying them?
Tom
97 Valkyrie
33344
« Reply #1 on: November 19, 2010, 09:34:45 PM »
The Standard/Tourer Valks have different ICM's than the Interstates. The 6 deg is for the Standard/Tourer and the 4 deg is for the I/S. Never bought one, can't help you on that question.
wild6
(Old enough to know better)
Vernon, NJ
« Reply #2 on: November 20, 2010, 04:28:38 AM »
I did the ECT mod.  Gave me about 4mpg more.
I think it's better than the trigger wheel because:
1. It is (optionally) adjustable up to 10°.
2. It makes the bike easier to start when cold because it doesn't add to the ICM's advance.
3. It's shut off when the transmission is in neutral preventing high idle rpm.
4. It fades out above 3k rpm letting the ICM do the job.
« Last Edit: November 20, 2010, 04:34:28 AM by wild6 » Logged
Buda
Buda IL
« Reply #3 on: November 20, 2010, 12:39:36 PM »
I am looking into the ECT mod sounds interesting.
Tom
97 Valkyrie
33344
Challenger
« Reply #4 on: November 20, 2010, 04:24:51 PM »
Buda: I did the ECT mod on my STD and really like being able to turn it off or down depending on what fuel I can buy (IE) (87 to 93)  The resisters, diodes and knobs came in multiples so I have extras if you want hem. all you need is the 10k taper. Even if you bought everything you need it is only about $15.00. and if you don't like it you can just shut it off or remove it easily. You can feel the difference,
John U.
Southern Delaware
« Reply #5 on: November 20, 2010, 05:52:28 PM »
+1 on the ECT mod. I also agree that you need the potentiometer for the ability to turn it off. It also gives you the variability to control how much advance you want to run. Without the Pot. you'll get 10 degrees of advance which is a bit too much IMHO.
Sorry, typing faster than the brain works I guess, I meant ECT mod.
« Last Edit: November 20, 2010, 05:54:18 PM by John U. » Logged
BackPack
« Reply #6 on: December 15, 2010, 06:57:17 PM »
I put on a 6 and picked up 4-6 mpg. Very good low end torque. They say you will loose a little top end speed but I've never had the nerve to try it. It will past just about anything on the road anyway.
