September 12, 2025, 04:08:59 PM *
Author Topic: A few months back I  (Read 1571 times)
iba1990
Rocky Mountain High !
Thornton, Colorado
« on: November 21, 2010, 04:14:23 AM »
A few months back I asked if anyone knew why my sickle was feeling squirrely in curves & turns. Someone suggested that I check my rear shock upper tower bushings...I did & they were shot. He also gave me a company name to buy some. I bought them & finally got around to installing them. WHOA!!! What a difference. The ones I removed were totally no good. The new ones are made of a very hard material & they work great...no more squirrely feeling. Before I installed the new ones I had to sorta go slow on curves & corners as it felt like I was going to lose control if I pushed it. Now I can smoke my knees in turns. What a difference. If you start getting that squirrely feeling in turns check out your shock tower bushings. Probably should check them periodically anyway as preventitive maintenance concern. I apoligize for not remembering who made the suggestion that I change them but thank you for the suggestion. I hope all of you enjoy your week-end. tommy t
bigvalkriefan
On the green monster
South Florida
« Reply #1 on: November 21, 2010, 04:21:55 AM »
.....say to those with fearful hearts, "Be strong, do not fear; your God will come, he will come with vengeance; with divine retribution he will come to save you."
Isaiah 35:4
I know who wins in the end.
robin
Get on it and RIDE!!
Hardwick NJ
« Reply #2 on: November 21, 2010, 04:48:48 AM »
So where did you get them from?
PAVALKER
Pittsburgh, Pa
« Reply #3 on: November 21, 2010, 07:07:14 AM »
On both the Valk and VTX I am using the VTX F Model lower shock bushings (their uppers are roller bearings).... try Honda part number 52489-HN0-671   Much different and better than the stock rubber bushings.
Some others on the VTX board are using hard Nylon bushings from McMaster Carr     http://www.mcmaster.com/#item/6389K344
Here is an interesting post on the VTX board that discusses some shock bushings, which are the same as ours for the most part.
http://www.vtxoa.com/forums/showthread.php?t=242281&highlight=shock+bushing
« Last Edit: November 21, 2010, 07:11:14 AM by PAVALKER » Logged
John
« Reply #4 on: November 21, 2010, 08:11:07 AM »
These are the best Robin IMO and you would be hard pressed to find someone better to deal with  cooldude
http://www.xf6-custom.com/partpages/bushings.html
Big IV
Iron Station, NC 28080
« Reply #5 on: November 21, 2010, 09:16:00 AM »
I did mine a while back. It is an easy fix for a part that suffers from wear.
"Ride Free Citizen!"
VRCCDS0176
iba1990
Thornton, Colorado
« Reply #6 on: November 21, 2010, 04:35:17 PM »
F-6 Design. See Smokin' Joe's post above. Really good parts.
PAVALKER
Pittsburgh, Pa
« Reply #7 on: November 21, 2010, 04:58:48 PM »
Joe,
Are those hard (solid) bushings or are they pliable to some degree?   They seem a tab pricey .... but if they NEVER need replaced, it might be worth it.
John
Jess Tolbirt
White Bluff, Tn.
« Reply #8 on: November 21, 2010, 06:27:44 PM »
I got 6 bushings for 4 dollars someplace here on the net,, found the link in the tech section i think...
iba1990
Thornton, Colorado
« Reply #9 on: November 22, 2010, 03:44:46 PM »
They are very hard. Not rubbery at all. VERY nice.
alph
Eau Claire, WI.
« Reply #10 on: November 22, 2010, 03:53:14 PM »
Just out of curiosity, have you checked your swing arm bearings?  If they go bad you’ll also get a squirrely feeling in your back end.
iba1990
Thornton, Colorado
« Reply #11 on: November 22, 2010, 05:42:48 PM »
The Swing Arm bearings seem to be good. No laterial movement. The shock tower bushings did the trick for me. tommy t
