I decided to follow the direction that some of you took with the aircraft landing light add-ons and couldn't be happier. They really perform well...In fact the Harley rider in front of me said when we stopped at the top of the mountain, he thought he was about to be run over by a 4 x 4 that had Rack lights overhead when I came upon him. I want to wire them to the starter switch so I won't leave them on, so that's the next phase. I didn't run them all the way home, and when I got home, one of the fuses that supply a feeder wire to the relay (which I mounted in the faring) had blown. When I replaced it, it blew again. Next step will be to remove the gas tank and inspect the wiring etc; because everything appears to be ok, I just think it may have gotten burnt or crimped. I used some plastic conduit across most of the engine, but I know the Valk engine runs pretty hot.
Thus, here's my question: When you have run wiring from the battery area to the faring have you had the same issue? (I used #10 wire for the feeders) I suspect whatever it is will show up when I pull the tank etc; but since I was sitting at the office etc; thought I'd get some feedback. Thanks for your input, and to those who gave tips on the install.
