cfloyd
« on: November 24, 2010, 05:35:12 PM » |
Did Honda put clear coat on all Valkyrie wheels? I have a 2000 standard and just assume that they were clear coated at the factory. I am about to spend some time polishing and some products such as White Diamond are not suppose to be used on coated surfaces.
Any information would be very much appreicated.
By the way, please enjoy your Thanksgiving with family and close friends.
Trynt
« Reply #1 on: November 24, 2010, 06:28:39 PM » |
2000 to 2003 Valk Wheels came clear coated from the factory.
Thunderbolt
« Reply #2 on: November 24, 2010, 06:53:06 PM » |
when clear coated wheels came about. From Dag's Valkyrienorway site.
MODEL DIFFERENCES
Year to Year
Differences from the previous years’ model (other than color)
Model Standard Tourer Interstate
1997 Engine:
• VPKOA carb (49-state).
• VPKOB carb (Calif).
• Jet needle J6KG. Engine:
• Jet needle J6KG.
1998 Engine:
• VPKOJ carbs (49-state).
• VPKOK carbs (Calif.).
• Jet needle J6KJ.
• Cyl Head P/N change.
Frame:
• Larger front wheel bearing
(with different seals and axle).
• Black wire wrap added to lower radiator hose. Engine:
• Jet needle J6KJ.
Frame:
• Larger front wheel bearing (with
• “Tourer” emblem added to windshield trim. 1999 Frame:
• Chrome horn cover added. Frame:
• Seamless hardbags.
2000 Engine:
• “Made in USA” no longer appears on engine.
• Engine Coolant Temp Indicator Unit eliminated (sensor now
directly controls LED).
Frame:
• I/S -style turn signals (no screws in lense face).
• New Seat design (I/W ‘97-’99).
• Seat height changed to 28.9” from 29.1”.
• Chrome wire wrap added to lower radiator hose.
• “Made in USA” no longer on rear seat.
• Tank badge changed from “F6” to Maidenhead design.
• Heavier rear brake rotor (caused different wheel, caliper
bracket and rotor mount bolts).
• Extra protective boot on start relay.
• Polished rear transfer case.
• Lower triple clamp P/N change. Engine:
Frame:
• Heavier rear brake rotor (caused different wheel, caliper bracket and rotor mount bolts).
• Extra protective boot on start relay. Frame:
(added to 2000 models
in production in late ‘99)
2001 • Polished & clearcoated wheels
• Front wheel is only machined
outside of brake rotor shadow.
Differences between US 49-State and California Models
Engine:
BigM
« Reply #3 on: November 24, 2010, 07:37:25 PM » |
Evidently some of the 2001 were clearcoated. But my 01 I/S is not. Wish it did. Look much better.
NITRO
« Reply #4 on: November 24, 2010, 08:16:58 PM » |
Weird that yours wasn't, BigM. I thought all were clear coated from '01 on. Did you buy the bike new?
My 2000 Standard didn't have clear coated, not does my 2000 IS. I now have a '01 rear wheel on the IS that is clear coated.
When in doubt, ride.
RonW
« Reply #5 on: November 25, 2010, 04:51:31 AM » |
the wheels on my 2000 Tourer does seem to have a clear coat layer. Sure looks like it. That brooches the question on what to use to polish clear coated wheels.
2000 Valkyrie Tourer
Disco
Republic of Texas
« Reply #6 on: November 25, 2010, 07:23:44 PM » |
My 2000 Standard did not have clearcoated wheels when I got it...
2000 Bumblebee "Tourer", 98 Yellow & Cream Tourer, 97 Rescue blower bike 22 CRF450RL, 19 BMW R1250RT 78 CB550K 71 Suzuki MT50 Trailhopper .jpg) VRCC 27,916 IBA 44,783
« Reply #7 on: November 26, 2010, 08:33:27 AM » |
A real good inspection of the wheels will reveal whether or not they are clear coated.
Especially easy if there is another Valkyrie alongside to compare with.
An easy test is a little aluminum polish in a small area. Won't take much rubbing to produce a little shiny place compared to the surrounding area!
Bagger John - #3785
« Reply #8 on: November 26, 2010, 12:20:58 PM » |
To the best of my knowledge, 2001-2003 Standards were the only models to get clear-coated wheels.
If your pre-2001 STandard/Tourer model or 2001 I/S has them, odds are the OEM (polished only) units have been swapped at some time.
Hoghead
« Reply #9 on: November 26, 2010, 12:47:07 PM » |
Put some aluminum polish on a liittle spot and rub it. If your rag turns black they are not clearcoated.
2000 I/S. Coronado Blue & Silver 1984 V65 Magna. Really Fast Black E. Texas Patriot Guard Rider
