September 12, 2025, 06:15:45 PM *
Author Topic: Sagging Hopnel windshield bag 3 pouches  (Read 963 times)
Chiefy
Sarasota, Florida
« on: November 26, 2010, 07:51:54 PM »
My Hopnel 3 pocket belt on the WS is pretty old, and is starting to sag pretty good.  It's hard to see the Speedo.  I like the weathered look, or I'd buy something new.
I need to stiffen it up some though, so I can see the speedo.  I'm sure I could "Rube Goldberg" something together that would work, but was wondering if anyone has "been there, done that" and can share what they've done.
« Reply #1 on: November 26, 2010, 08:47:01 PM »
Mine did the same thing. I was gonna take the plastic off and use some lexan in its place. Couldn't figure how to do the pouches without making it look bad. I ended up buying the HD 3 pouch set up for $95. Fits the contour of the oem shield excellant with minor adjustment. Far better quality pouches and can haul more since its metal backed.
Chiefy
Sarasota, Florida
« Reply #2 on: November 28, 2010, 10:12:44 AM »
LOL, between 1 inch risers I was installing anyway, and a small black binder clip, problem solved.  The Tach is only blocked near the red line, so if the needle disappears behind the pouch, I know I'm at the edge  Evil
The speedo was blocked 0-50 mph.  A binder clip on the right side, under the flap fixed that.  I unhooked the lever from the clip, and you can't even see it, it's black.
Quicksilver
Norway Bay, Quebec, Canada
« Reply #3 on: November 30, 2010, 06:30:56 PM »
I used linseed oil on a pair of leather chaps once. Made them so stiff they could stand up on their own. Just a thought.
1997  Standard
