September 12, 2025, 06:15:53 PM *
Author Topic: Rear Wheel Bearings  (Read 1197 times)
Dubsvalk
Knoxville, TN.
« on: November 30, 2010, 07:50:50 AM »
I am gathering parts to use when I pull the rear wheel for service on my 1998 Valk Tourer and I want to do the double bearing mod while I have it apart.  Can someone give me the part number for the double ball bearing that I need and also how much I have to remove off the spacer to allow the bearing to fit.
Bernie
Vietnam Veteran 1968/69
MSF Instructor
« Reply #1 on: November 30, 2010, 08:12:28 AM »
Here is the link to the ShopTalk article that XRING did on the double row bearing mod.
http://valkyrieriders.com/shoptalk/5204_bearing_mod.pdf
Everything you need to know is in this article.
Hope this helps,
Hay  Cool
« Reply #2 on: November 30, 2010, 08:55:11 AM »
Bernie
STOP..........the bearing will fit!  The internal spacer (between the bearings is NOT changed) will work as it always worked.
The change is made to the little external "hat" looking spacer that goes on last right before you slide the axle through the left side of the swing arm.  you grind off the difference between the two bearings is all
Dubsvalk
Knoxville, TN.
« Reply #3 on: November 30, 2010, 09:23:27 AM »
Thanks guys!  I appreciate the info and link!
Bernie
MSF Instructor
« Reply #4 on: November 30, 2010, 02:20:51 PM »
Bernie you can get the spacer machined in South Clinton...He did mine along with Paul and Greg's as well for $10.00 each.Takes him about 5 minutes after he gets it set-up.
Dubsvalk
Knoxville, TN.
« Reply #5 on: November 30, 2010, 02:53:33 PM »
Joe,  I will get with you when I get my parts collected to go to the machine shop you are talking about.
Bernie
MSF Instructor
« Reply #6 on: November 30, 2010, 03:08:47 PM »
Bernie
« Reply #7 on: November 30, 2010, 05:26:09 PM »
http://www.jkozloski.com/generic_parts.htm
B
Capital Area - Michigan
« Reply #8 on: November 30, 2010, 09:03:27 PM »
I may be a grease monkey but I don't have access to a machine shop. Sure would be nice if someone were to start selling those modified spaces. Wink
Dubsvalk
Knoxville, TN.
« Reply #9 on: December 01, 2010, 05:32:29 AM »
For $10.00 I will have a local machine shop cut mine for me but if none were available, I would mark the spacer and cut it with a dremel tool being very careful.  I have done it before on car parts.  The trick is being careful.
Bernie
MSF Instructor
