July 22, 2025, 03:24:46 AM *
Author Topic: Crush washer for oil drain bolt and final drive drain bolt- Same??  (Read 2213 times)
donaldcc
Palm Desert, CA
« on: December 04, 2010, 12:25:42 PM »
  soon to change back tire and getting final drive parts.  are these 2 washers the same item??
   Also need coolant drain bolt sealing washer # 90463-ML7-000 and cannot find it on http://www.directlineparts.com/store.asp?str=2 where I am getting other items.  uglystupid2
Don
Bone
« Reply #1 on: December 04, 2010, 12:45:38 PM »
Went to HDL and used my 98 Tourer for the search. Both washers are listed with the same part number. 94109-14000 @ 14 mm. That says they are the same washer.
I didn't look for the coolant washer but entered the number you posted in the search bar and got the below results.
WASHER (6.5MM) (90463-ML7-000)  $2.50
donaldcc
Palm Desert, CA
« Reply #2 on: December 04, 2010, 01:18:35 PM »
  Thanks, bone.  got it.  cooldude
Don
john
tyler texas
« Reply #3 on: December 04, 2010, 03:28:55 PM »
no new washers in 7 years of oil changes ...     coolsmiley
no problemo ...     Smiley
vrcc # 19002
« Reply #4 on: December 04, 2010, 03:40:53 PM »
ditto +1, doesn't need to be replace unless its leaking.
donaldcc
Palm Desert, CA
« Reply #5 on: December 04, 2010, 04:44:07 PM »
  thanks for info guys.  I had recently changed oil and did replace the washer though as you say it likely did not need it.  Will change final drive oil when rear tire is off so was wondering about that washer.  got a pack of 10 from HDL for $3.24 so at 32 cent each I just splurged and replaced it with oil and will do the same with the final drive oil change (what the heck, 32 cents).
  I don't think coolant has been changed on my '97 tourer now with 18,000 mi (7,000 from me in the last 6 months) so will change that soon though it looks good to me.  do you replace the washer there? or only if problem??
   And I just changed spark plugs that had been changed 8,000 miles ago. OEM plugs and no problems, but I wanted to make sure they came out easy and wanted to take a look at them to make sure they looked like all cylinders firing appropriately.  they looked good to me with no abnormal deposits or burned areas so I think I am good for a while after rear tire and final drive.   New plugs were about $2.50 each NGK from autozone so I went for new there also, but will likely increase interval between changes.
  All six plugs looked like these, look good to me.  cooldude
Don
9Ball
« Reply #6 on: December 05, 2010, 02:14:37 AM »
I always replace the radiator drain bolt washer.  It's a small copper washer and very expensive if you buy from the dealer.  I think some have found similar replacements at the hardware stor for a few cents, as opposed to a few dollars.
I'm sure mother Honda has a reason for this washer being made out of copper instead of aluminum...my guess is to prevent or minimize galvanic corrosion to the carbon steel drain bolt in an aluminum radiator.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
ILcruiser
Crystal Lake, IL
« Reply #7 on: December 05, 2010, 05:36:43 AM »
Those plugs are the poster children for good A/F mixture  cooldude
1999 Valkyrie Standard
« Reply #8 on: December 05, 2010, 08:39:30 AM »
If you use Never-Sieze on spark plug threads, you'll never have to worry if they come out easily.
