Simply ascertaining that the bolt is tight on a loose shifter is doing nothing.
You ought to find out where exactly the looseness is occurring.
It's loose in 2 places. The worse of it comes from the shaft wiggling around in the case. There's no oil leaking, so the seal is good. And from what others are saying, that seems to be normal.
There is also a little slack on the ever where it connects to the shaft. I'm worried the splines are going to wear like that, so I'll be putting something on there to tighten it up a bit (loc-tite or something of the like) as mentioned above.
I am guessing you are talking about play on the shaft area of the shifter,I too was surprised by the sloppiness in the shaft. Thought there may be a problem ,so I called a fellow valk rider had him check his. Same thing. I later checked myself comparing it to a few others ,same thing.
That sounds good. If the shaft itself typically has a little play but doesn't cause problems, then I should be good with just a little tightening of the lever connections on the shaft.
Thanks to all for the input!!
