July 22, 2025, 03:24:44 AM *
Author Topic: radiator flush  (Read 1738 times)
N0tac0p
« on: December 08, 2010, 05:17:24 AM »
I while back i asked about a process for radiator flush, ie chemicals, soaking, flushing ,etc.  i only got a repsonse look at change coolant in shop talk.
well, that doesn't answer the question.
anyone ever do a radiator flush?  what to use?  cautions?
« Reply #1 on: December 08, 2010, 06:11:24 AM »
cautions?
Animals sometimes think radiator fluid smells and tastes good... and it kills them in
a miserable way... be careful with it...
Earl in Pensacola
« Reply #2 on: December 08, 2010, 06:31:37 AM »
To be honest I have always done the "simplest" of flushes.  By that , I mean I just disconnect the lower hose, remove the radiator cap and let-her-drain.  I then  suck out the reserve tank with a "turkey baster".  I then start refilling the radiator (about half way) then start the engine.  Once I can see the coolant, I rev (just a  little) the engine a few times, put the cap on, rev her a few more times, go for a short ride.  turn off the engine, let her cool, recheck the radiator and top off.  99% of the time, that's it until it's time to do it again. My ride is still using the OEM radiator after 230K.
Earl in Pensacola
« Reply #3 on: December 08, 2010, 06:33:45 AM »
PS:  I forgot to say that I refill the reserve tank to about a third of the way up.
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #4 on: December 08, 2010, 08:53:57 AM »
notacop......i set the bike upright in a chock, and while cold do these things:  pull drain plug on bottom of water pump/take off radiator cap/remove overflow tank-drain and clean it, and reinstall it.  then i lightly reinstall water pump drain plug, and refill radiator with just clean water, and redrain water back out.  now for the refill:  install drain plug with new washer back into water pump/refill radiator with honda premixed antifreeze to full mark/ fill overflow tank to full line with honda premixed antifreeze/start engine, and let idle for a few minutes/snap throttle 3-4 times/shut off engine/check both radiator, and overflow tank to make sure each are on full mark/reinstall radiator cap, and your done.   cooldude
9Ball
« Reply #5 on: December 08, 2010, 12:52:17 PM »
the normal procedure is "drain and fill" as opposed to what you are calling a radiator flush.
Unless you are having overheating problems associated with a scaled-up radiator or are dealing with a very neglected radiator, that's all you need to do.  Shop talk gives all the info you need for a drain & fill.
I doubt anyone here has had to do much more than this for routine maintenance of their cooling system.
« Last Edit: December 08, 2010, 12:56:14 PM by jrhorton » Logged
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
« Reply #6 on: December 08, 2010, 03:00:16 PM »
If you drain it and the drainage looks really bad, go ahead and stick a hose in the top and let it run thru the system for awhile.  Drain and fill with 50/50 (and a dose of Water Wetter).
