February 01, 2026, 02:38:45 PM *
Author Topic: Manual for CB/Radio Control  (Read 4626 times)
Andy #7759
Berlin, Germany / Pottstown, PA
« on: December 13, 2010, 11:03:04 AM »
as some of you know, the Interstate was never sold in the EU.
All Bikes here where self imported or via resellers.
Problem that the Manuals are never sold with the bikes.
Who can send me a copy or a download link of the manual for the CB/Radio Control Unit
Andy VRCC #7759
Representive VRCC Europe
2qmedic
Simply Awesome!!!
« Reply #1 on: December 13, 2010, 01:24:34 PM »
Hello,
To my knowledge, there was never any manual...
The button on the front on the radio control-push untill there is a "CB" on the speedometer panel.
Squech -upper button closest to your left index finger. Adjust to high number to hear only the strongest signals. Adjust to lower numbers allow you to hear progressively weaker signals.
Adjust CB volume - depress the Vol Mode, then adjust the vol.
For external speaker vs helmet intercom - press the lower, most forward button;
     Press down - will change the out put location of the CB.
     Press up, it will change the radio out put location.
Did this by memory, may be only slight varation
Hope this helps Smiley
Bigmac2
California
« Reply #2 on: December 13, 2010, 04:42:19 PM »
Send me your email and ill send the manual in pdf form also have the install directions rmblaster@sbcglobal.net
Richard (bigmac2)
« Last Edit: December 13, 2010, 04:44:10 PM by Bigmac2 » Logged
« Reply #3 on: December 13, 2010, 08:19:06 PM »
Richard (bigmac2)
Maybe send a copy to Dag and have posted in Norway?
« Last Edit: December 13, 2010, 08:29:01 PM by gordonv » Logged
Disco
Republic of Texas
« Reply #4 on: December 14, 2010, 06:12:23 AM »
+1
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
MP
North Dakota
« Reply #5 on: December 14, 2010, 06:18:21 AM »
I believe it has been posted.
MP
"Ridin' with Cycho"
old grouch
Colorado Springs, CO
« Reply #6 on: December 14, 2010, 06:43:57 AM »
There actually is a separate manual which covers the use/functions of the CB radio.  I have one in front of me.  I do not, however have the capability/skill to get it into a format I can share.  The functions/use of the CB is also covered in the Owner's Manual, which I also have, but as stated can't share.  (see my reply to another post about this same subject, "F6C Interstate Radio Controller" on here, also from a Member in Germany)
    Stan
09/11/01 NEVER FORGET!
old grouch
« Reply #7 on: December 14, 2010, 06:47:07 AM »
Oh, by the way, I couldn't find the info Dag's site.  May be there, but I couldn't find it!   Undecided
    Stan
old grouch
« Reply #8 on: December 14, 2010, 08:01:34 AM »
You can buy one here:
http://www.repairmanual.com/online/official-2000-honda-gl1500cf-valkyrie-interstate-factory-owners-manual-31mby610/
Stan
Dag
Country Rep. Norway
« Reply #9 on: December 14, 2010, 02:15:05 PM »
You can find a few manuals in the "Valkyrie Document Center"  Wink
http://valkyrienorway.com/download.html
2qmedic
Simply Awesome!!!
« Reply #10 on: December 14, 2010, 05:05:41 PM »
Oops, my bad, Never knew of a CB manual. Always learning something new here.
Cheers
jwebber45
North Jersey
« Reply #11 on: December 15, 2010, 08:36:31 AM »
Richard (bigmac2)
Just checked, The operations manual is different and not listed on Dags site. Maybe you can send it to him so he can post it. Thanks. cooldude
cef2lion
Central PA
« Reply #12 on: December 15, 2010, 10:43:25 AM »
For radio operation I found a short instruction sheet that helps me. Doesn't Include the CB operation. Someone sent me a PDF on that.
1.  Pwr / Function button - press button to turn on radio and continue to
     press button to select the desired function.  Press and hold until you
     hear a beep to turn radio off (display will show time only).
2.  Volume lever - press up / down to raise / lower volume.  Holding lever in
     up / down position will rapidly increase / decrease volume.
3.  Band / Memo lever - Push up to change between AM and FM.  Push down
     to select stored radio stations.
4a. Tune lever - Push up to increase radio frequency, push down to decrease
       radio frequency.
4b. Seek feature - push lever up or down and release when you hear a beep.
      Seek stops when locating a station with a strong signal.
4c. You can preset 6 AM and 6 FM stations.  System will select stations in order
      they were entered into system.
     1.  To preset a station
       a.  Select AM or FM via the Band / Memo lever (push lever up).
       b.  Push Band / Memo lever down to select desired channel.
       c.  Push Channel Memo button - the CH indicator will begin to blink.
       d.  Push the Tune lever to desired station.
       e.  Push and hold Ch Memo button till you hear a beep.  Indicator will stop
            blinking and preset channel will be visible in the display.
     2.  Auto Seek - Press and hold Band / Memo lever down until you hear a beep.
         A. SEL will flash in display, and the system will go into the scan mode for
         several seconds.  It will scan both bands and store the 6 strongest stations
         in each band.  Use Band / Memo lever to select stations.
          To turn Auto Select off - press and hold Band / Memo lever until you hear a beep.
5.  Tone control
      A.  To select Bass, push the Audio Mode button until BA appears in the display, then,
           within 4 seconds, push Volume lever up / down to adjust bass level (+6 to -6).
      B.  To select Treble, push the Audio Mode button until TR appears in the display,
           then, within 4 seconds, push Volume lever up / down to adjust treble level
           (+6 to -6).
6.  Fader control
      A.  To balance between front and optional rear speakers, push the Audio Mode
           button until FA appears in the display.  Control volume by pushing the
           Volume lever up / down.
           (The control range: F (front) 9 to F1, 0, R (rear) 1 to R 9).
7.  Ambience (AMB) - Blends and boosts frequencies from both channels for a "live
     performance" effect.  AMB may be used for stereo programs from FM radio.
    The AMB circuit may make a weak FM stereo signals sound worse.
     A.  To use AMB - push Audio Mode button until Ab appears in the display
          (the Ab display may be on or off).  Then, within 4 seconds, change the
          ambience setting.
     B.  To change setting - push Volume lever up (Ab on) or down (Ab off).
8.  Auto Volume Control (AVC) - automatically increase volume as the speed of bike
     increases.
     A.  Push the V-Mode button until AVC appears in the display.  Within 4 seconds,
          adjust the volume by pushing the Volume lever up / down (there are 3
          settings: H (high), L (low), and OF (off).
9.  To switch the CB or Audio system between speaker and headset.
     A.  Push the SPKR/HS lever up to select AUDIO.
     B.  Push the SPKR/HS lever down to select CB.
10. Intercom Volume Control - Note:  some local governments prohibit the use of
     a headset by the operator of a motor vehicle.  The intercom system may be
     used to communicate with your passenger.
     A.  To adjust intercom volume, push the V-MODE button until the headset
          indicator appears in the display.
     B.  Push the Volume lever up / down to adjust the volume (note - intercom
          is hot mike, always on).
Clock
Turn the key on or to ACC> Radio ON > Push and hold the CLOCK button until you hear a beep and the
display starts blinking > Operate the VOLUMN lever to adjust the time, push the volumn lever up and
hold it until you reach the desired hour, then push the volumn lever down and hold it until you reach
the desired minute > Push the CLOCK button again to lock in the time display.
« Last Edit: December 15, 2010, 02:24:16 PM by cef2lion » Logged
Andy #7759
« Reply #13 on: December 15, 2010, 01:36:57 PM »
Thank's for your help my Friends.  cooldude
Problem solved.
Merry X-mas to everybody
Andy VRCC #7759
