lvchief
« on: December 14, 2010, 12:43:10 PM » |
So how do you undo the circular clips holding the brake, etc cables on the handlebars?
Valker
Wahoo!!!!
Texas Panhandle
« Reply #1 on: December 14, 2010, 01:58:16 PM » |
The male part slides sideways out of the other end.
Thunderbolt
« Reply #2 on: December 14, 2010, 04:52:40 PM » |
push the two halves apart sideways.
shortleg
« Reply #3 on: December 15, 2010, 03:57:26 AM » |
I found that with a good light and a small screwdriver pushed into the end, it will release the end and it will open. They are held on the barsby a small nob on the bars. with a clip that is snapped over it. Shortleg[Dave]
« Reply #4 on: December 15, 2010, 07:40:23 AM » |
Bust them off with a screwdriver, study them under a microscope and then buy new ones from HDL...  -Mike "I used to be able to see without glasses"
old grouch
Colorado Springs, CO
« Reply #5 on: December 15, 2010, 04:02:33 PM » |
"Bust them off with a screwdriver, study them under a microscope and then buy new ones from HDL... " If I do that, what part # do I use to order? Can't seem to find them on the HDL site.
 Don't float thru life, MAKE WAVES! 09/11/01 NEVER FORGET!
« Reply #6 on: December 15, 2010, 04:40:15 PM » |
Perhaps this will be more helpful than my first response...  I like to take pictures of stuff I can't see, details usually show up in the blown-up picture...   -Mike "I was at work..."
« Last Edit: February 04, 2015, 10:22:15 AM by hubcapsc »
old grouch
« Reply #7 on: December 15, 2010, 04:55:45 PM » |
Thanks!  I will order some to replace all my broken ones which are nearly all broken.
Big IV
« Reply #8 on: December 16, 2010, 07:03:15 AM » |
Black wire ties are sold at most dollar stores. Not reusable, but the original neat clips are barely reusable.
"Ride Free Citizen!" VRCCDS0176
« Reply #9 on: December 16, 2010, 07:59:53 AM » |
I use stainless steel picture hanging wire for my braided lines. Clean look.
« Reply #10 on: December 16, 2010, 09:08:10 AM » |
I use stainless steel picture hanging wire for my braided lines. Clean look.  bingo! Exact same here. I drilled a hole at the bottom of the bar and tapped in a philipss head screw. Wrapped the wire in the middle, secured the harness, twisted the ends of the wire and then hid the end into the top. Clean look and very easy. I just wrapped the wire around the post on the bars and then postioned the cable over the top of the post. all that is seen up close is the thin wire.
Big IV
« Reply #11 on: December 16, 2010, 01:49:16 PM » |
I'd like to see pictures of that! If either of you have up close pics. Or if you both post with comparisons I'd be appreciative.
« Reply #12 on: December 16, 2010, 03:30:09 PM » |
I believe the OE bar clips are one-inch for all the wires that must be enclosed on the Valk bars (there are smaller sizes available).
Some time back, I found replacement clips in chrome plastic.... but I can't find them anymore. Bet they're still out there.
« Reply #13 on: December 16, 2010, 03:54:41 PM » |
They are 2 different sizes for right and left side by the way.
« Reply #14 on: December 16, 2010, 04:08:27 PM » |
 I only see 15s on the 1997 Tourer page... -Mike
« Reply #15 on: December 16, 2010, 04:35:15 PM » |
« Last Edit: December 16, 2010, 04:37:14 PM by CA ExhaustCoatings »
Walküre
Nothing beats a 6-pack!
Oxford, Indiana
« Reply #16 on: December 16, 2010, 10:50:31 PM » |
Thanks! I will order some to replace all my broken ones which are nearly all broken.  Am I the only one that this brought a much-needed chuckle to? thanks for the giggle! Rather like "Deja Vu, all over again!".
2000 Valkyrie Standard 1999 Valkyrie Interstate 2000 HD Dyna Wide Glide FXDWGRoger Phillips Oxford, IN VRCC #31978 Yeah, what she said...
