February 01, 2026, 02:37:53 PM *
Author Topic: Elusive bolts, Why do I always need something that doesn't exist?  (Read 2888 times)
Jeff K
« on: December 19, 2010, 03:27:53 PM »
I'm working on a project and due to some clearance issues I need a flat head socket screw.
Here's the kicker
M10-1.25 X 20mm
SS of course. I'll be cursed if I can find a source for one.
 Angry
roboto65
Conroe,TX
« Reply #1 on: December 19, 2010, 05:53:41 PM »
You sure the bolt is 10 by 1.25 that is most likely 1.5 but anyway they maybe able to help here ya go..
http://www.boltdepot.com/dimension.aspx?cc=25&cs=83&cm=19
Allen Rugg
VRCC #30806
1978 Kawasaki KZ 650 project
Jeff K
« Reply #2 on: December 19, 2010, 06:12:26 PM »
It is 1.25 thread not 1.5
ILcruiser
Crystal Lake, IL
« Reply #3 on: December 19, 2010, 06:17:22 PM »
http://www.mcmaster.com/#socket-head-cap-screws/=a80bgq
1999 Valkyrie Standard
Jeff K
« Reply #4 on: December 19, 2010, 06:45:35 PM »
McMaster doesn't have any 1.25 thread flat heads... that I can find...
Jeff K
« Reply #5 on: December 19, 2010, 06:48:09 PM »
Well Jeff K ?  Did we do good?
Unless I'm missing something... I still don't see it...
chrise2469
Winnipeg Manitoba Canada
« Reply #6 on: December 19, 2010, 07:48:56 PM »
Try again  Roll Eyes
He's looking for flat head socket
There are none in m10-1.25 pitch that I could find.
Jeff, does it have to be a flat head? Would a taper or button fit? There are lots of taper and button.  I looked at about 40 sites and found only one flat head and it was in quantity 200.
Jeff K
« Reply #7 on: December 19, 2010, 08:12:40 PM »
Try again  Roll Eyes
Yeah, it has to be a flat.
I guess I have to come up with a new plan....
chrise2469
« Reply #8 on: December 19, 2010, 09:10:56 PM »
Jeff, how about some TI bolts at 6.13 a piece? Link to all bolts
http://www.probolt-usa.com/search.php?searchterm=Countersunk+Bolt+M10+x+1.25mm+
Individual 20mm bolt
http://www.probolt-usa.com/Products/titanium_bolts_countersunk_washers/TICS1020F
Found some in Great Britain 13.28 a pair before shipping
http://www.boltmeup.com/m10-x-20-stainless-125mm-fine-pitch-countersunk-bolts-8011-p.asp
Hope this helps- your search will broaden if you use countersunk bolt.
« Last Edit: December 19, 2010, 09:20:45 PM by chrise2469 » Logged
Jeff K
« Reply #9 on: December 20, 2010, 05:16:52 AM »
I didn't even think of going the titanium, great idea, thanks.
I'm doing a break upgrade on my Vmax and the adapter I made will require a countersunk bolt.
I'm putting hayabusa front calipers on it so the mount needs an adapter.
 I didn't think it would be a challenge to find a bolt. I have a bunch of 10-1.25 bolts in every style except countersunk.
chrise2469
« Reply #10 on: December 20, 2010, 05:29:06 AM »
Your welcome Jeff.  Soon as you get into the fine metric thread it becomes a pain to find and goes up in price.
Good luck and ride safe.
Jeff K
« Reply #11 on: December 20, 2010, 05:39:49 AM »
Wow. that is weird. I searched "M10-1.25 countersunk" and this thread shows up on the second Google page?
« Reply #12 on: December 20, 2010, 07:23:24 AM »
If you can go with a larger bolt,,,,
Drill and tap is always available as are chrome flat socket head cap screws in SAE sizes.
Jeff K
« Reply #13 on: December 20, 2010, 08:37:44 AM »
I have a clearance issue already, I really didn't want to go to bigger bolts.
