February 01, 2026, 04:12:29 PM *
Author Topic: OK so Im at Wal- Mart  (Read 4304 times)
« on: December 24, 2010, 07:05:37 PM »
And being Christmas Eve its crazy nuts busy in there.......so I decide to hide out a bit in the automotive section since noone was in there.  The only peaceful place in the store.  I was going to get a can of Seafoam because I hadnt run a can of it through in quite some time and there was some roughness around the edges as far as idle, low speed acceleration and deceleration.  Then the Techron caught my eye.  Seemed to be on sale or at least cheaper than usual and so Techron it is.
WOW!!!  I put the whole bottle (smaller than the Seafoam) 10oz I think....in just over a half tank and go riding.  after ten miles or so the idle was glass smooth and no hesitation on acceleration or deceleration.  Much better results then when I use the Seafoam.
I guess its Techron every few thousand miles from now on.
Tropic traveler
Silver Springs, Florida
« Reply #1 on: December 24, 2010, 07:31:42 PM »
Same good experience with Techron here.
Heavy dosed the black & silver '99 after I bought it. Cleared up the idle & ran smoother. It had sat around in a barn for at least 6 months prior,
Good stuff.
'13 F6B red for Kim
Farther
Quimper Peninsula, WA
« Reply #2 on: December 24, 2010, 07:54:01 PM »
That is why I run Texico or Chevron whenever possible.
~Farther
« Reply #3 on: December 25, 2010, 05:17:31 AM »
Huummm, and I just bought 3 gallons of Sea-foam..  Is Techtron a stabilizer too??
« Reply #4 on: December 25, 2010, 05:19:34 AM »
I'll have to try it. Had great resualts with the gumout regaine. Increaed my mpg.
« Reply #5 on: December 25, 2010, 05:55:05 AM »
I know a few guys that work at GM Fuel and Lube lab.  They told me years ago that the only fuel additive/injector cleaner that works is Chevron with Techron.  They tested it on fuel injectors which have nozzles that are much smaller than any jets in a carburetor.  It is a cleaner only, so will not do didley for stabilizing/preserving fuel, but does wonders for removing deposits.
PAVALKER
Pittsburgh, Pa
« Reply #6 on: December 25, 2010, 08:17:21 AM »
Hmmm, sounds like a plan.... Seafoam in the fall/winter over and Techron in the spring.   cooldude
John
2qmedic
Simply Awesome!!!
« Reply #7 on: December 25, 2010, 10:06:58 AM »
WOW, sounds impressive, I'll try that also.
Thanks for that post cooldude
ILcruiser
Crystal Lake, IL
« Reply #8 on: December 25, 2010, 10:17:14 AM »
Last time I checked, Techron was the only fuel additive approved by Honda for use in their motorcycle engines.  I use it twice a riding season, and also in my cars.  Very good stuff.  I'm not sure about using it as a stabilizer; I've always used Seafoam with no issues, and just don't see the need to change.
1999 Valkyrie Standard
Earl in Pensacola
« Reply #9 on: December 25, 2010, 10:24:40 AM »
Yea, when tht Seafoam went up by about 50% I switched to Chemtool B12 and it seems to do just as good of a job "keepin' her clean" and for about 1/3 the price!!
« Reply #10 on: December 25, 2010, 12:28:09 PM »
Except its not a stabilizer. But you are in a warm State.
Earl in Pensacola
« Reply #11 on: December 25, 2010, 01:28:03 PM »
Good point, as the bike only sets a few days at a time in the worst of weather, which is right about now for us.  However, I do use Stabil in my reserve gas for all the lawn equipment.  Actually, I also run B12 thru them once or twoice a year.
alph
Eau Claire, WI.
« Reply #12 on: December 26, 2010, 06:40:20 AM »
i'll agree with the Techron as a cleaner.  used it in my wifes van, made an increadibly noticable difference with it.  good stuff.  never used it in the cycle 'cause i think one bottle treats 15 gallons..... don't know if that'll ruin other parts of the carb if it's that strong.....
Farther
« Reply #13 on: December 26, 2010, 11:52:55 AM »
I am using the "new" Stabil for ethanol fuels in my bike right now.  It is twice the price but you use half as much.
~Farther
Hef
Opdyke, IL 62872
« Reply #14 on: December 27, 2010, 09:03:44 AM »
Kind of like the tire issue, everyone has an opinion and they don't always agree on what is the best. I like SeaFoam. It may not be the best and it's definitely not the cheapest, but it has always worked for me. I have used SeaFoam for many years now and I have never had a problem with my truck, car, motorcycle, four wheeler, or lawn mower when it comes to the fuel issue. So as I see it ....if it aint broke don't fix it!
brillo1542
wheaton, il
« Reply #15 on: December 27, 2010, 11:50:56 AM »
I also use Tectron because of the excellent cleaning properties.  My question is this: Can I use Tectron straight?  I am taking off the carbs this winter because most of the set screws for the needle jets are frozen.  (When I bought the bike, it was 6 years old and only had 2900 miles on it.)  I plan on soaking them to free everything up.  Is there any plastic in the carbs that might be damaged by the Tectron?
Thanks.
Paul
six2go #152
Ft. Wayne, IN
« Reply #16 on: December 27, 2010, 12:46:27 PM »
Uh, then don't use the whole bottle. Use the appropriate amount to treat 6 gallons or so.
desanshe
White Rock, British Columbia, Canada
« Reply #17 on: December 27, 2010, 08:17:29 PM »
Seasons greetings
I haven't seen this in Canada...Can anyone advise if and where it is available
Thx...Roger
Gator
« Reply #18 on: December 28, 2010, 06:25:28 AM »
Thx...Roger
Roger, you can get Techron at Chevron gas stations.
The shortest distance between points A & B is irrelevant on a Valk.
« Reply #19 on: December 28, 2010, 10:56:54 AM »
Seasons greetings
Hi Roger,
We have it, Canadian Tire should have it, I'm sure I've seen it there in the past, looking for injector cleaner. But like said already, should find it at Chevron.
