July 04, 2025, 06:55:22 AM *
Author Topic: Vibration when accelerating while cruising  (Read 2827 times)
valk2128
Suwanee, GA
« on: April 04, 2009, 04:25:53 PM »
When I am cruising around 45 mph in 5th gear, and I give it a lot of gas there seems to be  a good amount of vibration as the Valkyrie accelerates.
If I wind the gears there is no problem and it acclerates real well, without the vibration mentioned above.
Is this normal??
Zorba
Ride the Dragon
« Reply #1 on: April 04, 2009, 06:36:13 PM »
Have to feel where it's coming from , engine , wheels driveshaft etc?
At 45 in 5th you're almost lugging the engine , so when you gas it it might be a Normal engine strain vibration , gas from 55 and see if it vibrates ?
You're probably under 2500 on the take at 45 mph?
MITCH
Ropesville TEXAS
« Reply #2 on: April 05, 2009, 05:59:14 AM »
I think Zorba is on to something there with the lugging down theory. I have an I/S and in 5th gear at 45mph I’m running about 21K and if I goose it up there is a vibration up to 55mph then it will smooth out. However if I downshift it performs normally. cooldude
Grandpot
Fort Mill, South Carolina
« Reply #3 on: April 05, 2009, 09:03:14 AM »
I had the exact same conditions.  I synchronized the carbs and it got much better.  However, you will always have some vibration when you lug the engine.
