June 27, 2025, 04:09:24 PM
strange vibration
Topic: strange vibration (Read 2919 times)
shortstack
strange vibration
April 04, 2009, 04:52:42 PM »
Please help....I have a 98 Tourer with 26,000 miles. When I release the throttle in 3-5 gear and just before the power breaks away there is a pretty strong vibration or "grinding" sound coming from the motor. it's been happening for about a month or so. Doesn't seem to be effecting the power or anything else. Just my own concern. Thanks!!!
Re: strange vibration
April 04, 2009, 05:09:49 PM »
Could be the U-joint or drive shaft splines that go into the pinion cup. Sounds transfer quickly so its hard to tell where they are coming from, but it sounds like a U-joint to me......easy to check and not too expensive to replace.
Zorba
Ride the Dragon
April 04, 2009, 06:38:41 PM »
Next time you release it "pull in the clutch" and see if it does it ?
And at what speed are you talking ?
April 05, 2009, 08:20:51 AM »
Look hard at the universal joint! If it were to let go, there is a possibility of greater damage than just the universal. Under strain the universal will run true, but at a mid-point where strain is relieved you will then get a vibration from unbalance in the universal that is being allowed to run in an untrue condition. This is mainly caused from the universal having to rely on two splines for alignment. The spring help a lot but there is still the engineered sloppiness from the splines.
shortstack
April 05, 2009, 11:33:46 AM »
Thanks for the help so far guys.....very helpful!! the sound is happening at speeds from 40mph and up. I really only notice it right when the throttle is releasing power.
Disco
Republic of Texas
April 06, 2009, 06:31:47 AM »
I have seen final drive problems happen much sooner than u-joint failures. One local guy changed his at 100,000 mainly because he was replacing a rear tire and was already in there. It was tired, but could have gone farther.
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
VRCC 27,916 IBA 44,783
=> InZane XXV
