February 01, 2026, 04:11:50 PM
My bike seems kinda loose in the corners
Topic: My bike seems kinda loose in the corners (Read 1809 times)
HotRod
Henderson, NV
December 26, 2010, 09:59:38 AM »
Not sure if it's just me trying to dip too low in the corners or what,or maybe riding her daily I'm noticing thing I wouldn't normally worry about. Just fells loose,idk,I guess I'll start checking torque on the nuts and bolts,air pressure ect.
Re: My bike seems kinda loose in the corners
December 26, 2010, 10:10:11 AM »
Air pressure in the rear tire and/or worn out shock rear bushings would be my guess.
Hay
Westsider
Fort Worth TX.
December 26, 2010, 10:19:15 AM »
Whats kind of tires ?
Are you getting to ride this weekend?
we'll be there when we get there - Valkless,, on lookout....
Tundra
2014 Valkyrie 1800
Seminole, Florida
December 26, 2010, 11:05:51 AM »
Start with simple...check your tire pressure. I check mine every week. With the fluctuation in temperature lately, could be that simple. Then take a looksie at your shock bushings.
Farther
Quimper Peninsula, WA
December 26, 2010, 11:45:02 AM »
Quote from: HayHauler on December 26, 2010, 10:10:11 AM
+1. Get the urethane VTX or other urethane bushings offered by a forum member.
~Farther
Black Dog
VRCC # 7111
Merton Wisconsin 53029
December 26, 2010, 11:53:36 AM »
Worn Shock Bushings will give you a 'wallowing' feeling, like not being able to hold yer arc through the turn...
Look at the upper shock bolt. It should be dead center in the shock eye... If not, yer bushings are worn.
Black Dog
Don't you know...
