September 13, 2025, 10:09:00 AM *
Author Topic: Whats a great flashlight?  (Read 2962 times)
HotRod
Henderson, NV
« on: December 31, 2010, 12:09:41 PM »
  Been looking on line at a Remington flashlight with a 150 lumes for about $38 bucks,cant seem to find one I like locally. Maybe E-Bay?
Jess Tolbirt
White Bluff, Tn.
« Reply #1 on: December 31, 2010, 12:46:18 PM »
goto Lowes and get the mag light with the 3 watt LED in it,,,i have a 3 watt 2 cell and it will burn the hair off a cats butt at 300 yards,,,,
« Reply #2 on: December 31, 2010, 01:00:19 PM »
Cheesy
I have a Mag as well in my tractor trailer I've had it for years and can't count the times I've dropped it....Still works like new ....IMO a good bang for the buck.
alph
Eau Claire, WI.
« Reply #3 on: December 31, 2010, 01:08:09 PM »
I will never buy another mag lite again.  I don’t know about the LED ones, but I know the old ones that take 2AA batteries suck!!  I’ve had four of them over the last 15 years, and all four of ‘em needed to be smacked on the wall to get them to be 100% bright, not to mention the batteries always “leak” in ‘em.  My favorite flash light is one that I have for my 14.4v DeWalt cordless drill.  It’s got a Kryptonite bulb that’s super bright.  I mean extremely bright!!  It stays lit for three hours straight.  That’s the one I like.
HotRod
Henderson, NV
« Reply #4 on: December 31, 2010, 01:20:03 PM »
Is that one that you can carry on your belt? I should of been more specific. I want one for my belt with the push button on the tail,seems like others I've been trying are on when I go to retrieve it from the pouch.
blotar
VRCC #32549 VRCCDS#0237
Crosby, Texas
« Reply #5 on: December 31, 2010, 03:04:04 PM »
Check out the energizer Lithium LED. A little pricey ($38) but has 65 lumens, waterproof, clips on your pocket w/back button and will dimm way down to conserve the one aa battery. Very strong and looks like it's going to last.
http://vrcc.photostash.com/vrcc_32549/VisitedStatesMap3.jpg
1998 Valkyrie CT
1995 V-Max [img width=347 height=175]
1995 Yamaha Virago 1100
1994 Suzuki GSX 1100 G
1995 Honda Shadow 1100
1994 Honda Magna 750
196? BSA Hardtail
1973 K3 Honda 750
1964 Allstate 250
keystone kid
« Reply #6 on: December 31, 2010, 05:57:59 PM »
Try the Redline Nebo light.  You can look it up online.  Great price and a lot of flashlight.
Marcel
« Reply #7 on: December 31, 2010, 06:00:12 PM »
The most powerful flashlight in the world!powered by Aeva
Or you could just buy a small hand torch at Wally World.
That clips on you hat bill for a few bucks.
According to what your intended use is.
This is a model from Cheap A$$ Tools . Com
http://toolmonger.com/2010/07/19/cheap-ass-tools-novelty-pocket-led-flashlight-for-450/
« Last Edit: December 31, 2010, 06:08:02 PM by Marcel » Logged
Jess Tolbirt
White Bluff, Tn.
« Reply #8 on: December 31, 2010, 07:28:55 PM »
look at the led and if it is the round type dont buy that one,, you want the one that is flat....
they come in either size like the mini mag or the regular size...
mine will burn for 2 weeks solid,, i left it in the attic and found it 2 weeks later and still as bright as ever,,
the cheep flashlights are just that, cheep,, mine cost 30 bucks and when i lost it i bought another,,,and i am a cheep old bas** well you get the point,,,
BigChris99
Hesperia CA
« Reply #9 on: December 31, 2010, 07:49:17 PM »
Leatherman Monarch 500...Yes,the same Leatherman that makes the great multi-tools. The flashlights are very good. The Monarch 500 is the same size as a Mini Mag light, it fits in my Mag light sheath. It runs on two AA batteries and it is BRIGHT. It blows a Mini Mag away. It's LED, so no shaking or hitting it to make it bright. It just works.  Also, has the tail switch you are looking for. On and off. Simple. I work a night shift and use mine every night. And yes its been drop tested! I bought my daughter one to have in her dorm room at college. Google it. About 30 bucks, and worth it.
In 5th gear.... looking for 6th
VRCC # 35023   IBA # 7849
« Reply #10 on: December 31, 2010, 08:54:02 PM »
The AA mimi Mag can be found for under $10 with a sheath. Then you get a www.niteize.com adapter for it. It has a 1 watt LED and a button on the bottom. The button can get you 3 brightness levels and a slow and rapid flashing mode. Total price is under $30.
« Reply #11 on: December 31, 2010, 08:57:05 PM »
Website for the exact conversion kit.
http://www.niteize.com/collections/new-products/products/led-upgrade-combo-2
Wingman
« Reply #12 on: December 31, 2010, 09:57:10 PM »
I use a Surefire E2D like this one:
http://www.amazon.com/SureFire-E2D-LED-Lumens-E2DL-BK/dp/B001QU6RTQ
It is the best flashlight I've ever owned. I use it at work and carry it everywhere.
9Ball
« Reply #13 on: January 01, 2011, 01:49:22 AM »
thanks...I have a few of these and one I pack on the bike for traveling and I will definitely get this upgrade....neat stuff.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
JP in SC
Palmetto State Valk
New Prospect, Upstate SC
« Reply #14 on: January 01, 2011, 09:03:32 AM »
  My name is John, and I'm a Flashoholic!
  If you want a "great flashlight" you should consider the Streamlight Stinger LED DS. It is rechargeable, has both the tailcap switch you want and a switch on the head. The light has 3 operating levels from about 180 lumens down to 45 lumens as well as a strobe capability. If you have to work around reflective areas with it you really learn to appreciate being able to dim it down. You can get it with AC or DC chargers, or both. Mine came with the piggyback charger and a spare battery. The piggyback charger allows you to charge the spare battery out of the light.
  For about 20 years I thought that MagLights were the only flashlights worth carrying. Four years ago my work supplied a xenon bulb stinger for me to carry on the job. It's a good light except for the decreasing output of the incandescent bulb as it gets older(30 hr rated bulb life). I bought the LED stinger and it has replaced the work light (now rides around in the truck ) and the MagLights (almost all converted to LEDs, now sitting around the house, shed, cabinets, etc.).
  The only thing I would like to change on mine is that it doesn't have the tailcap switch.
  The streamlight LED DS is around $100 to $120. Here's a link to the Streamlight product page http://www.streamlight.com/product/product.aspx?pid=135
John
98 Standard - Black & Chrome
04 ST1300
HotRod
Henderson, NV
« Reply #15 on: January 01, 2011, 12:09:02 PM »
That is one bad mother! a little rich for my blood but would love to have one,incredible!
HotRod
Henderson, NV
« Reply #16 on: January 01, 2011, 12:20:21 PM »
HI JOHN, My name is Rod and I think I may be a flasaholic too,that was funny. Nice flash light .
scoot
Lifes too short Ride it hard
Grand Rapids Mi.
« Reply #17 on: January 01, 2011, 03:46:57 PM »
Just run across this tonight
http://www.creativelightings.com/LED-Flashlights-and-LED-Gadgets-s/1548.htm
T.P.
Apple Valley, Minnesota.
« Reply #18 on: January 01, 2011, 03:55:54 PM »
HEY HOTROD,  I picked up one of these last fall, LOVE IT !
http://www.surefire.com/G2-Led
JP in SC
Palmetto State Valk
« Reply #19 on: January 01, 2011, 06:42:03 PM »
A really good place to research flashlights is at http://www.flashlightreviews.com/index.html. He does in-depth reviews and testing of a wide variety of flashlights.
You can also get a lot of really good info on the candlepower forum at http://www.candlepowerforums.com/.
John
04 ST1300
Sharkey
GOT CURVES??
VRCCDS0184
« Reply #20 on: January 02, 2011, 08:35:46 AM »
Hows it going Rod
Cabelas has the Surefire G2 on sale right now for 39.99 dont know if that a good buy or not
http://www.cabelas.com/product/Bargain-Cave/Camping/Lights-Accessories%7C/pc/105591780/c/105770880/sc/105773580/SureFire174-G2174-LED-Flashlight/1139372.uts?destination=%2Fcatalog%2Fbrowse%2Fbargain-cave-camping-lights-accessories%2F_%2FN-1102813%2FNs-CATEGORY_SEQ_105773580%3FWTz_l%3DSBC%3B105591780%3Bcat105770880&WTz_l=SBC;105591780;cat105770880;cat105773580
¿spoom
WI
« Reply #21 on: January 02, 2011, 05:54:46 PM »
Can't say enough good about the Romisen line http://www.shiningbeam.com/servlet/the-By-Manufacturer-cln-Romisen/s/17/Categories I got my RC-C6 II Q5 about a year ago and it's great. Probably newer ones by now but this is a solid performer and you can't beat their battery prices at Shining Beam either.
B
Capital Area - Michigan
« Reply #22 on: January 02, 2011, 08:38:02 PM »
Streamlight survivor...what a lot of firefighters carry. $55 on Amazon.
