February 01, 2026, 04:12:40 PM *
Author Topic: Need new front tire...  (Read 2532 times)
Printer Mike
Eatonton, Georgia
« on: December 31, 2010, 05:25:34 PM »
Does $249 for a Dunlop EliteIII sound about right(installed ,balanced, w/ new stem)?
Thanks...
Never give up!
bigdog99
1/1/2011 86,000 miles
Kouts Indiana
« Reply #1 on: December 31, 2010, 05:32:24 PM »
http://www.valkyrieforum.com/bbs/index.php/topic,18775.msg160221.html#msg160221
and a $98 car tire in the back
id say yes that sounds right. i still think it wrong. if you could change your own its worth it. 3,000  miles on a back tire in the front and its amazing
VRCC#31391
VRCCDS0239
« Reply #2 on: January 01, 2011, 03:56:15 PM »
3K miles, or 3K miles more, from a back tire when used on the front, instead of a front tire?
blotar
VRCC #32549 VRCCDS#0237
Crosby, Texas
« Reply #3 on: January 01, 2011, 06:03:07 PM »
Hey, What's all this stuff about a back tire turned backwards on a front wheel? Undecided I am going DS next weekend at the local Wrench Session and I couldn't be more exited!! But I cannot figure out this cunnnundrum... back tire turned around on a front wheel. I know that the back tire in question is supposed to be a bias ply tire. Also I am trying to get my mind around the directional issue. I thought that most of these tires are directional.
 Blotar
http://vrcc.photostash.com/vrcc_32549/VisitedStatesMap3.jpg
1998 Valkyrie CT
1995 V-Max [img width=347 height=175]
1995 Yamaha Virago 1100
1994 Suzuki GSX 1100 G
1995 Honda Shadow 1100
1994 Honda Magna 750
196? BSA Hardtail
1973 K3 Honda 750
1964 Allstate 250
John U.
Southern Delaware
« Reply #4 on: January 01, 2011, 07:01:57 PM »
The idea of a back tire on the front is to get some extra mileage anfdmaybe some added traction. The back tirse have a thicker tread than the fronts. The recomendation to run them backwards is about the braking stress on the front rather than the acceleration stress on rear tires. It has worked for many folks and it suggested by at least one tire manufacturer.
blotar
Crosby, Texas
« Reply #5 on: January 01, 2011, 07:09:21 PM »
Thanks John,
  That is a great expanation and a question that has been driving me crazy.
Blotar
1998 Valkyrie CT
196? BSA Hardtail
1973 K3 Honda 750
1964 Allstate 250
bigdog99
Kouts Indiana
« Reply #6 on: January 01, 2011, 07:53:08 PM »
currently at 3,000 miles, would have had a noce flat spot started with the E3's. this tire still looks brand new. backward bias on the front and a CT on the rear is the way to go for me.
have a happy new year all. cooldude
VRCC#31391
VRCCDS0239
Warlock
Magnolia, Ms
« Reply #7 on: January 02, 2011, 04:55:15 AM »
 Blotar
Here's a picture of my Avon rear tire turned backward on the front. Size 130/90/17 Speedometer reading the same as the stock size.
David
« Reply #8 on: January 02, 2011, 08:56:13 AM »
 Blotar
David
David would you feel comfortable with that same tire turned around the correct way?   Does it have a directional arrow ?
Warlock
Magnolia, Ms
« Reply #9 on: January 02, 2011, 10:58:09 AM »
 Blotar
David
It has a directional arrow. Running it that way because of braking issue. If you look at a Avon Venon front tire and roll it beside that one the thread pattern almost the same.
David
« Reply #10 on: January 02, 2011, 11:02:19 AM »
Its been said many times. The directional rotation arrow, doesn't show the direction the tire rotates, but shows the direct the tire must rotate in relation to the forces that act upon it, based upon the way the tire is manufactured.
The rear tire has accelerational force placed upon it, and the front tire has braking force on it. You could take a front tire and place it on the back, but remember to turn it around, because it is no longer having braking force applied upon it, but now needs to have the accelerational force.
« Last Edit: January 02, 2011, 11:05:17 AM by gordonv » Logged
bigdog99
Kouts Indiana
« Reply #11 on: January 02, 2011, 03:09:48 PM »
this is the kenda, it does make the speedo a lil off. but it last and last.
VRCC#31391
VRCCDS0239
B
Capital Area - Michigan
« Reply #12 on: January 02, 2011, 08:54:21 PM »
I paid $160 for mine +$30 mount&balanced (off the bike). That was our local Honda guy (Mid-Mi) back in June.
Jess Tolbirt
White Bluff, Tn.
« Reply #13 on: January 03, 2011, 05:09:37 AM »
i am going to put in my 2 cents here,,
look at the tread on the front tire turned backwards,,,if you run thru rain the tread will pull the water into the center of the tire instead of throwing it away from it causing you to hydroplane the tire,,,
i like the idea of a rear on the front but i would not run it backwards,, you also have braking force on the rear just like the front, the only difference is that there is a constant force under power but the rear coast just like the front too,,sooooooo when i put mine on i will put it on like it goes,,,
opinons are like armpits,,,everyone has a couple and they both stink,,,
Valkyrie member # 23084
roboto65
Conroe,TX
« Reply #14 on: January 03, 2011, 06:26:07 AM »
Hate to inform you but if you look at your front tire you will notice that they all run towards the center backwards that the nature of the beast.
Allen Rugg
VRCC #30806
1978 Kawasaki KZ 650 project
