February 01, 2026, 04:11:53 PM *
Author Topic: My nuts are rusty!  (Read 1888 times)
DarkMeister
« on: January 01, 2011, 03:27:02 AM »
And many of the bolts as well. Not sure what's with that, but it seems if I as much as tighten a bolt, the hex hole will show rust within days. Anyone have a simple way of removing the rust? I tried rubbing with CLR, no dice.
The worst of it is the accelerator cable and nuts where it meets the grip. That one, and maybe the clutch cable, I just may have to replace. Angry
Bone
« Reply #1 on: January 01, 2011, 04:02:59 AM »
Soak them in Cider  Smiley     sorry couldn't resist.
Quicksilver
Norway Bay, Quebec, Canada
« Reply #2 on: January 01, 2011, 04:40:46 AM »
Rust Remover made by Dominion Sure seal Ltd. Available Canadian tire.
Be careful, contains phosphoric acid.
Quicksilver
1997  Standard
Garfield
97 Standard
Phoenix, AZ
« Reply #3 on: January 01, 2011, 04:46:43 AM »
My nuts are rusty
So are mine now that I just got turned down flat all night long  Cry 2funny 2funny
3W-lonerider
Shippensburg Pa
« Reply #4 on: January 01, 2011, 05:04:29 AM »
once you get the rust removed put clear finger nail polish on the hexes,bolts and nuts..and redo it everytime you touch them with a wrench..and they won't rust again.
DarkMeister
« Reply #5 on: January 01, 2011, 09:33:31 AM »
Thanks folks! For the hints and the chuckles. I'll hit CT tomorrow. Clear nail polish....next week. cooldude
Momz
ABATE, AMA, & MRF rep.
« Reply #6 on: January 01, 2011, 05:34:48 PM »
If your allen bolts and screws start to rust,...clean them with vinegar and a Q-tip. Then take Anti-Seize and apply with a clean Q-tip and wipe off any excess with a paper towel.
Works like a charm!
ALWAYS QUESTION AUTHORITY!
« Reply #7 on: January 02, 2011, 12:49:25 PM »
Works like a charm!
I second the motion....an old but effective method. Works well on the metal ones. As for the flesh-toned version....you're on your own.  Wink
