February 01, 2026, 04:12:03 PM
Normal for rear wheel spin in gear w/ clutch in?
Topic: Normal for rear wheel spin in gear w/ clutch in? (Read 1799 times)
Garland
#618
Hendersonville NC
January 02, 2011, 09:56:55 AM »
Today I replaced the shifter seal (thank you Daniel Meyer!) on my 99 Tourer w/ 75k miles. The bike was on the centerstand already, so I started it up and ran through the gears with the clutch in to make sure I got the shift linkage in the correct position. I noticed the rear wheel spins slowly while in gear. Is my clutch not disengaging fully, or is this normal?
roboto65
Conroe,TX
Re: Normal for rear wheel spin in gear w/ clutch in?
January 02, 2011, 10:15:15 AM »
This is normal
Allen Rugg
VRCC #30806
1978 Kawasaki KZ 650 project
Momz
ABATE, AMA, & MRF rep.
January 02, 2011, 03:59:39 PM »
+1
Well,... most of the time.
ALWAYS QUESTION AUTHORITY!
roboto65
Conroe,TX
January 02, 2011, 05:13:03 PM »
It also happens when you rev it up hold the front brake and dump the clutch
Allen Rugg
VRCC #30806
vanagon40
Greenwood, IN
January 02, 2011, 08:43:42 PM »
Quote from: roboto65 on January 02, 2011, 05:13:03 PM
If you perform the above procedure and your rear wheel "spins slowly" as reported by the OP, I think you have a problem (unlike the OP whose bikes appears to functioning normally).
Brad
Reno, Nevada
January 02, 2011, 09:40:03 PM »
You better hope that's what happens....could launch the front wheel into the air and take you for a nice ride.
