September 13, 2025, 10:09:50 AM *
Author Topic: new grips for christmas  (Read 1975 times)
bigdog99
1/1/2011 86,000 miles
Kouts Indiana
« on: January 02, 2011, 03:46:44 PM »
Anyone know the quickest, safest and easiest way to swap out handle bar grips?
VRCC#31391
VRCCDS0239
Momz
ABATE, AMA, & MRF rep.
« Reply #1 on: January 02, 2011, 04:12:00 PM »
I would remove the exsisting grips, clean the bars, then simply install the new grips by following the instructions provided.
Simplicity, is always easier to deal with than trying to reinvent an instalation process. JMHO
ALWAYS QUESTION AUTHORITY!
bigdog99
Kouts Indiana
« Reply #2 on: January 02, 2011, 05:01:48 PM »
thanks
VRCC#31391
VRCCDS0239
RP#62
Gilbert, AZ
« Reply #3 on: January 02, 2011, 05:07:24 PM »
Are the ones you're removing stock?
-RP
bigdog99
Kouts Indiana
« Reply #4 on: January 02, 2011, 06:09:30 PM »
yes, they are stock.
VRCC#31391
VRCCDS0239
Valkahuna
DeLand, Florida
« Reply #5 on: January 02, 2011, 09:07:26 PM »
Changed a LOT of grips in my dirt riding days. Best thing to use is to spray the inside of the new grips with hair spray. Makes em slide on really easy, and when dry works better than any glue. cooldude
2014 Indian Chieftain
2001 Valkyrie I/S
« Reply #6 on: January 02, 2011, 09:31:26 PM »
The best tool to get off old grips is an ice pick.... and WD40 with long nozzle.
Screw off the end caps, carefully slide the ice pick in between the grip and bar, then sister-up (slide) the WD40 skinny nozzle in next to the ice pick and spray (pull nozzle out while spraying).  Do three or four times around, and the grip should slide right off.  Some here like the stock grips and may be willing to pay you something for them.
Me, I hate all stock grips, and I always just took a utility razor knife and cut them off and threw them away.
Clean off all old glue with gas and sandpaper/scuff up the chrome bar ends before you glue on the new grips.  If you are using super glue or something that dries quickly, always do the throttle grip first, its harder to get right, then you can match up the left side to the throttle side.  I used RTV silicone as glue because I can take 20-30 minutes to position them where I want them (instead of the 2.5 seconds you have with super glue).  RTV must set up for 12-24 hours before riding, and will come loose about once a year (no big deal to redo).
bigdog99
Kouts Indiana
« Reply #7 on: January 03, 2011, 08:20:05 AM »
thanks again  on the way to new grips! cooldude
VRCC#31391
VRCCDS0239
flatsixlover
Catonsville, MD Patriot Guard Rider VRCC#28566
« Reply #8 on: January 03, 2011, 08:46:27 AM »
I used my air compressor and a basketball needle to remove my old grips, worked great, no fuss, no muss.   cooldude
Clean off all the old glue and I test fit each side and marked the new grip & handlebar with a sharpie so that when pushing on with the epoxy I knew where to line up each grip.
Hope this helps.
« Reply #9 on: January 03, 2011, 08:58:30 AM »
+1 on the WD40 and the ice pick, easy as pie.
Hay  Cool
« Reply #10 on: January 03, 2011, 09:51:41 AM »
Hay  Cool
Off topic............ you ever try to make pie, from scratch?    tickedoff
Cooking is nuts and bolts..... but baking is an art.
I don't know where the expression 'easy as pie' came from but making good pie (especially the crust) is not easy.
Now if the expression means easy as EATING pie, then I completely understand.
On a related topic, speaking of eating pie and all the other holiday fare, anyone got a good way to quickly get rid of ten pounds of ugly fat...........besides cutting off my head.    crazy2
« Reply #11 on: January 03, 2011, 09:55:19 AM »
I will agree, the crust is impossible for me...
Hay  Cool
BamaJack
McCalla, Alabama
« Reply #12 on: January 03, 2011, 10:02:17 AM »
Have a look at this link, step by step pictures...
http://bigbf.com/bigbf_shop/grip_criuse/
Jack in Bama - vrcc#10322      Phyllis (PeeK) in Bama - vrcc#19668
2000 I/S Super Valk                   2000 Tourer
1999 Interstate                          2003 Standard
Gator
« Reply #13 on: January 03, 2011, 10:17:56 AM »
It's easy Jess:
One pound of tool shed roof is equivalent to consuming 3500 calories of food. Therefore 10 lbs is equal to 35000 calories. Men need 2000 to 2500 calories per day to maintain normal weight and energy. At 2000 calories per day, if you don't eat for 18 days you will burn up 36000 calories worth of fat and loose more than 10 lbs.  cooldude
If you compliment with an exercise regime such as vigorous twisting of the throttle grip (back on topic  Cheesy ) weight loss will occur more rapidly.
I'm in the same boat. Man, it's gonna be tough this time.
The shortest distance between points A & B is irrelevant on a Valk.
bigdog99
Kouts Indiana
« Reply #14 on: January 03, 2011, 10:50:04 AM »
looks like something VRCC is good at. the site helps a lot with the pics,   now it looks like i have to make a pie crust when done.  coolsmiley any pics for that one!!!! 2funny
VRCC#31391
VRCCDS0239
BamaJack
McCalla, Alabama
« Reply #15 on: January 03, 2011, 02:24:17 PM »
At the risk of being branded a smarta$$... try this...
http://www.joyfulabode.com/2008/09/15/how-to-make-flaky-pastry-pie-crust-step-by-step-with-photos/
Michvalk
Remus, Mi
« Reply #16 on: January 03, 2011, 02:30:41 PM »
My New Years resolution will be easy to keep! I'm gonna buy bigger pants! Cheesy Grin cooldude
« Reply #17 on: January 03, 2011, 03:00:57 PM »
I'm gonna buy bigger pants!  2funny
OK smart ass, this is why I really don't need to know how to make good pies... I don't need to be eating any of that pogey bait.
I make great oatmeal cookies, and oatmeal is good for you.   angel
ricoman
Sarasota, FL
« Reply #18 on: January 03, 2011, 03:44:56 PM »
Hope this helps.
+1 on the air, so easy and quick
if you use a throttle lock be careful the grip isn't too tight against it
sugerbear
wentzville mo
« Reply #19 on: January 03, 2011, 04:30:53 PM »
i lost 30 lbs in 15 days(9 in the hospital), but, you prolly don't want to go that way. Shocked
« Reply #20 on: January 03, 2011, 04:38:33 PM »
A permanent change of diet.  Reduced carbs and almost no refined sugar.  If it's white, it's likely bad for you.
Fourteen days in a hospital is a great head start, but you may want to skip that step.
« Reply #21 on: January 03, 2011, 04:46:09 PM »
Oh, and on the grips, be certain not to overdo the glue on the throttle sleeve.  Glue between the grip and the switch housing is a bad thing.
Both my posts are from personal experience.
« Reply #22 on: January 03, 2011, 09:46:02 PM »
I really don't have a bad diet, just much less activity in Winter.  Time to fire up the treadmill.
I'll definitely skip the Hospital diet - food - expense - fun.  Though I'm nuts about tight nurses whites  (I once married my afternoon shift nurse, in an earlier life).   She gave good bed bath.  crazy2
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #23 on: January 04, 2011, 03:11:55 AM »
+1, I slice mine down the middle with a razor and toss them, junk!
