« on: January 04, 2011, 11:43:24 AM » |
I need to reglue the gasket on my trunk, on my version it goes around the top edge of the trunk bottom and the lid comes down over it. After painting it, the kid tried to glue it down using some form of epoxy and really made a mess. I pulled the gasket off immediately and spent an afternoon cleaning up his mess. Now, I just have the gasket sitting in place with the lid latched down, figured I'd just leave it that way so it will take a "set" while I come up with a good glue. Any suggestions on something that will hold the gasket in place and not pull up when I open the lid?
« Reply #1 on: January 04, 2011, 11:55:48 AM » |
My first thought was the product called Goop, or something like that (I used it and it dried and I threw it away).
My second thought was silicon caucking, are someother like product, that is water proof. You need to check out if the cleaning product for the caucking removal will eat the ABS plastic. Just incase it needs to be removed sometime in the future for another repair/paint job.
olddog1946
« Reply #2 on: January 04, 2011, 12:02:25 PM » |
automotive weather strip glue should work well... or some high temp glue used to put drum seals on a clothes dryer....any appliance repair shop will have a ton of it laying around...you get enough to do about a half dozen seals in every kit..
VRCC # 32473 US AIR FORCE E7, Retired 1965-1988 01 Valk Std. 02 BMW k1200LTE 65 Chevelle coupe, 1986 Mazda RX-7 with 350/5spd, 1983 Mazda RX-7 with FOMOCO 302/AOD project, 95 Mustang GT Convertible 5.0, 5 spd Moses Lake, Wa. 509-760-6382 if you need help
« Reply #3 on: January 04, 2011, 01:07:16 PM » |
used black silicone for my saddle bags. I think it actually states for weather stripping on the package
« Reply #4 on: January 04, 2011, 03:15:13 PM » |
Gorilla glue worked real good for my hardbag gaskets. Got it at Harbor freight. hoser
NITRO
« Reply #5 on: January 04, 2011, 07:32:30 PM » |
I used some clear silicone that Alph had in his garage to re-attach mine. It's held just fine.
When in doubt, ride.
MP
North Dakota
« Reply #6 on: January 05, 2011, 06:00:24 AM » |
3M weatherstripping glue
 "Ridin' with Cycho"
ILcruiser
« Reply #7 on: January 05, 2011, 06:06:17 AM » |
Honda grip cement is great for bonding rubber to metal.
1999 Valkyrie Standard
chip
« Reply #8 on: January 05, 2011, 08:25:56 AM » |
3M weatherstripping glue  I wouldn't over do it with whatever you use. When it comes time for removing it for any reason you want it to come off in one piece,
2000 I/S ,03 Standard ,Yes, I like mine BLACK !
shortleg
« Reply #9 on: January 05, 2011, 01:46:15 PM » |
I am with the 3M weather strip adhesive. Worked on saddlebags of my old tourer  Shortleg[Dave]
« Reply #10 on: January 05, 2011, 05:44:43 PM » |
It's black, very runny which makes it easier to spread. I've only done one section for now, just want to see how it holds. First impression is good however. I went across the front where the latches are, and about 3" around the corners on each end. The corners are always the area where you're going to have a problem..if at all. As instructed on the package, I spread a film on the inside of the gasket, then on the matching surface of the trunk. Let it sit for a minute or so, then slipped it in place. Just a little pressure in the corners and it holds it down. I closed the lid and will let it sit overnight with the pressure of the latched lid on it. If that part is good in the morning, I'll finish it. I ended up spreading it with my finger(much easier and effective), both on the trunk surface and inside the rubber. Took me ten minutes to get it off my finger with Goof-Off. Some real sticky stuff.
Brad
« Reply #11 on: January 05, 2011, 06:35:43 PM » |
Yep this be the stuff.
Garfield
97 Standard
Phoenix, AZ
« Reply #12 on: January 05, 2011, 09:31:02 PM » |
Yep this be the stuff.  I tryed to pick up some today at a small hardware store. The person working there took me to the weather stipping instead. I guest they didn't carry it, because he did not know what it was. Will try another place tomorrow.
Brad
« Reply #13 on: January 05, 2011, 10:26:09 PM » |
Yep this be the stuff.  I tryed to pick up some today at a small hardware store. The person working there took me to the weather stipping instead. I guest they didn't carry it, because he did not know what it was. Will try another place tomorrow. I buy it from an automotive paint supplier...one who sells to the body shops because they have to use this stuff on most of the cars they work on.
Garfield
97 Standard
Phoenix, AZ
« Reply #14 on: January 05, 2011, 10:31:10 PM » |
Yep this be the stuff.  I tryed to pick up some today at a small hardware store. The person working there took me to the weather stipping instead. I guest they didn't carry it, because he did not know what it was. Will try another place tomorrow. I buy it from an automotive paint supplier...one who sells to the body shops because they have to use this stuff on most of the cars they work on. Thanks Brad, theres one two blocks away from me. I'll check them out in the morning.
« Reply #15 on: January 06, 2011, 07:57:14 AM » |
http://www.acehardware.com/product/index.jsp?productId=1419000enhanced picture shows it being used for weather stripping, listed as adhesive
