December 21, 2025, 08:15:42 AM *
Author Topic: Wanting to "do" my carbs...  (Read 1161 times)
us385south
"Geeky White Caucasion"
San Marcos, Texas
« on: January 16, 2011, 04:15:13 PM »
I am approaching the idea of rebuilding my carbs.  Fixin' too... for me that means thinking about getting ready too...
I like to collect as many parts as I am able in advance... that means questions of folks that are way smarter than I am.  I thought I start on the Texas board first... as you guys are close at hand and have thus far been very gracious to the noob.
First: it appears from the Honda parts fiche that there isn't really a kit.  Does anyone else make a kit?  Maybe k&L?  If I am best going OEM What parts should I get?  Needles, jets and...
Two: I figured to rebuild the petcock, replace all the vacuum hoses, replace the fuel filter and add a quick fuel disconnect while I am in there.  (what the heck... it's just money right?) I already have a new air filter.
Three: do I need anything other than that?  Should I invest in the de-smog kit too?  I'm not real sure what that is... or what the advantages are to installing one.
Thoughts?  Suggestions?  Nuggets of wisdom?
"I can't explain a blessed thing,
not a falling star or a feathered wing,
but when the light's just right I swear I see...
poetry!"
Pete
« Reply #1 on: January 16, 2011, 04:59:15 PM »
O-rings for the slow speed needles (6)
O-rings for the head to intake joints (6)
Carb bowl gaskets (6)
High quality carb cleaner, spray and liquid.
Air compressor for blowing out the passages after cleaner.
Common hand tools to do the job especially a 1/4 inch socket set.
"Nothing runs better that a clean set of carbs"
godfire
Republic of Texas
« Reply #2 on: January 19, 2011, 07:24:24 AM »
 I have no affiliation with Red Eye Technical Services, other than I'm a satisfied customer.
But if you want to do your cabs I suggest that you start here...
http://redeye.ecrater.com/c/414983/carb-intake-seal-kits
Ride Safe
Ride Often
Westy
Center Hastings Ontario
« Reply #3 on: January 19, 2011, 02:49:21 PM »
I second godfire, nothing but the best from red eye tech.  I am a satisfied customer.
