March 21, 2026, 01:29:45 PM *
Author Topic: defintion of acceleration  (Read 1173 times)
laserpat
Cedar Park, Texas
« on: January 17, 2011, 05:51:14 AM »
DEFINITION OF ACCELERATION
One top fuel dragster 500 cubic inch Hemi engine makes more horsepower than the first 4 rows of stock cars at the Daytona 500.
It takes just 15/100ths of a second for all 6,000+ horsepower of an NHRA Top Fuel dragster engine to reach the rear wheels.
Under full throttle, a dragster engine consumes 1-1/2 gallons of nitro methane per second; a fully loaded 747 consumes jet fuel at the same rate with 25% less energy being produced.
A stock Dodge Hemi V8 engine cannot produce enough power to drive the dragster's supercharger.
With 3,000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ignition.
Cylinders run on the verge of hydraulic lock at full throttle.
At the stoichiometric (stoichiometry: methodology and technology by which quantities of reactants and products in chemical reactions are determined) 1.7:1 air/fuel mixture of nitro methane, the flame front temperature measures 7,050 deg F.
Nitro methane burns yellow... The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases.
Dual magnetos supply 44 amps to each spark plug. This is the output of an arc welder in each cylinder.
Spark plug electrodes are totally consumed during a pass. After halfway, the engine is dieseling from compression, plus the glow of exhaust valves at 1,400 deg F. The engine can only be shut down by cutting the fuel flow.
If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with sufficient force to blow cylinder heads off the block in pieces or split the block in half.
In order to exceed 300 mph in 4. 5 seconds, dragsters must accelerate an average of over 4G's. In order to reach 200 mph (well before half-track), the launch acceleration approaches 8G's.
Dragsters reach over 300 miles per hour before you have completed reading this sentence.
Top fuel engines turn approximately 540 revolutions from light to light! Including the burnout, the engine must only survive 900 revolutions under load.
The redline is actually quite high at 9,500 rpm.
Assuming all the equipment is paid off, the crew worked for free, and for once NOTHING BLOWS UP, each run costs an estimate $1,000.00 per second.
The current top fuel dragster elapsed time record is 4.428 seconds for the quarter mile (11/12/06, Tony Schumacher, at Pomona , CA ). The top speed record is 336.15 mph as measured over the last 66' of the run (05/25/05 Tony Schumacher, at Hebron , OH ).
Putting all of this into perspective:
You are driving the average $140,000 Lingenfelter 'twin-turbo' powered Corvette Z06. Over a mile up the road, a top fuel dragster is staged and ready to launch down a quarter mile strip as you pass. You have the advantage of a flying start. You run the 'Vette hard up through the gears and blast across the starting line and pass the dragster at an honest 200 mph. The 'tree' goes green for both of you at that moment.
The dragster launches and starts after you. You keep your foot down hard, but you hear an incredibly brutal whine that sears your eardrums and within 3 seconds, the dragster catches and passes you. He beats you to the finish line, a quarter mile away from where you just passed him.
Think about it, from a standing start, the dragster had spotted you 200 mph and not only caught, but nearly blasted you off the road when he passed you within a mere 1,320 foot long race course.
 ...... and that my friend, is ACCELERATION!
Tony Schumacher 4.428 @ 327 MPHpowered by Aeva
Marcel
« Reply #1 on: January 17, 2011, 06:49:15 AM »
I think this one is a example of what all that power can do.
How many times has this guy been blown up and on fire.
NHRA Drag Racing John Force Crashpowered by Aeva
Kaiser
Gainesville, FL
« Reply #2 on: January 17, 2011, 09:12:32 AM »
I only went that fast on my Valk one time - and I swore I'd never do it again.
Seriously though (and I've often wondered about this) - it's gotta feel like it takes FOREVER to get home after a race.  I mean - you were just doin' 300+MPH and now you are doin' 70MPH?
Stormrider65
Ft.Worth, Texas
« Reply #3 on: January 17, 2011, 09:25:40 AM »
I saw a program demonstrating acceleration.  It was done at a racetrack, oval.  There were 3 vehicles, a stock family car(station wagon), a nascar vehicle, and a formula 1.  The station wagon took off first, and the guy in the formula was smoking a cig without his helmet or headsock.  After a bit the nascar takes off, the formula looks bored, then finally starts to put on the headsock and his helmet, gets in his formula, and finally takes off.  The station wagon is outrun by the nascar, but WAY before the nascar gets near the 3rd turn the formula passes him like he's on jacks.  It was really neat to see.
Walt
In this wild and wolly world, there are only 3 things you can depend on, your brains, your bros, and your bike.  Ride free!!!
A good friend will bail you out of jail.  A true friend will be sitting next to saying "Damn, That Was Fun"
« Reply #4 on: January 17, 2011, 09:54:06 AM »
That made me start wondering...
This is from the Saturn V wiki page...
In flight, the center engine was turned off about 26 seconds earlier than the outboard engines to limit acceleration. During launch, the S-IC fired its engines for 168 seconds (ignition occurred about 7 seconds before liftoff) and at engine cutoff, the vehicle was at an altitude of about 42 miles (68 km), was downrange about 58 miles (93 km), and was moving about 7,850 ft/sec (2,390 m/sec, or approximately 5,352 mph
