November 22, 2025, 07:40:15 AM
So, what is the optimal
Topic: So, what is the optimal (Read 1361 times)
old grouch
Colorado Springs, CO
January 17, 2011, 07:00:18 PM »
vacuum reading for a Valk? What is the optimal compression reading? How much variation is acceptable in the compression reading? I know somebody out there knows this.
TIA, Stan
09/11/01 NEVER FORGET!
Re: So, what is the optimal
January 18, 2011, 04:43:46 PM »
Compression should be in the 155 to 165 range, evenness is more important than pressure. Vacuum should be around 15 inches vacuum is going to be harder because you measure one cylinder at a time and have to smooth the pulses. Again evenness between cylinders is more important than the actual pressure of course if you have 95 then there's a problem
old grouch
January 18, 2011, 05:50:06 PM »
Thanks, Robert. Stan
=> InZane XXV
