September 13, 2025, 05:30:32 PM *
Author Topic: Harbor Freight 36" Lift  (Read 1870 times)
blackvalk
PARK CITY, UTAH
« on: January 18, 2011, 02:27:43 PM »
I was in Harbor Freight on Sunday and found a motorcycle lift that raises a bike up to 36". With a 20 percent discount the price is about $160.00.
Does anyone have this lift. It seemed much heavier than a standard bike lift, which I already have. The advantage is lifting the bike 36". It seems like a pour mans mechanic's lift that you ride up on and use hydraulics to lift the bike.
I will have a bolt on lift adapter installed shortly and thought this may be a great option.
What say ye?
Warlock
Magnolia, Ms
« Reply #1 on: January 18, 2011, 02:48:05 PM »
If it is the one that raises like a forklift I have one. If you was close enough I would make you a good deal on it. Only used it a couple times. I just don't trust it. It might do great, but when I lifted my Tourer I didn't like the way it would sag over.
David
blackvalk
PARK CITY, UTAH
« Reply #2 on: January 18, 2011, 03:11:51 PM »
It did look like a fork lift. It really looked strong so I'm surprised it sagged. That's scary!
Warlock
Magnolia, Ms
« Reply #3 on: January 18, 2011, 04:56:07 PM »
I'm thinking about carrying it and have a strong back welded on it for piece of mind. Got a buddy that has a welding shop.
David
« Reply #4 on: January 18, 2011, 06:36:32 PM »
Is it this one?
http://www.harborfreight.com/high-position-motorcycle-lift-99887.html
Their web site says it only goes up 30".
Ken Tarver
North Mississippi
« Reply #5 on: January 18, 2011, 07:52:50 PM »
what i don't like about this type ~ when bike is on it you can't roll it around into another spot in the shop ~ NO i wouldn't try tipping it back on those casters to move it. I guess it may be low enough to add some casters to all 4 corners ~ that might work. there is another brand simular that has a screw jack instead of bottle jack, it can be raised with a drill
Ken
Warlock
Magnolia, Ms
« Reply #6 on: January 18, 2011, 07:55:23 PM »
Is it this one?
That's the one I have. Mine gives where the fork is welded to the vertical tubing.
David
Ken Tarver
North Mississippi
« Reply #7 on: January 18, 2011, 08:40:04 PM »
http://www.stands-and-lifts.com/index.php?option=com_content&view=frontpage&Itemid=1
here it is~with screw lift~not my bike, but is the same color!
Dogg
Berlin Md
« Reply #8 on: January 18, 2011, 10:21:07 PM »
I have 2 harbor frieght table lifts. 1 I use in the garage, the other is sitting in storage till i can make more room. its air over hydraulic and is 36 inches wide, raises just over 36 inches and locks. plus has a removable plate for rear tire access. delivered to my door for under 500$ each. not too bad i thoguth and it works great. even came with a screw type wheel chock to keep it still and upright. very stable.
blackvalk
PARK CITY, UTAH
« Reply #9 on: January 19, 2011, 03:32:27 AM »
This is the style of lift I did find at Harbor Freight.
The screw type seems a little more stable considering it lifts on a solid piece of steel not arms. The comment on the weak mounting spot where the horizontal arms meet the vertical really sounds dangerous.
And, you are right the lift height is 30" not 36"
I will research the price on the screw type and post it later.
Jess Tolbirt
White Bluff, Tn.
« Reply #10 on: January 19, 2011, 04:47:04 AM »
850 pound motorcycle held up by only one support point? probably welded in china...i think i would pass on that lift.. i have the short lift and one day will maybe get the platform type, but that one would scare me...
stude31
Topeka,ks
« Reply #11 on: January 19, 2011, 05:47:52 AM »
Dogg, I think I have the same one you have in storage:
It works good, just make sure you stilll secure the bike it is a bit heavy but it sure does help out working on the bike.
I think I paid 425.00 for it plus a 20% off coupon. Here's a link to print the coupon.  http://slickdeals.net/forums/showpost.php?p=33166821&postcount=1619
And here is the lift:  http://www.harborfreight.com/1000-lb-capacity-air-hydraulic-motorcycle-lift-94121.html
Oh and you can pick up a wheel chock for 25.99 with a coupon here: http://images.harborfreight.com/hftusa/itc/7731/images/7.jpg
I hope this helps Smiley
blackvalk
PARK CITY, UTAH
« Reply #12 on: January 19, 2011, 01:34:52 PM »
The Blue lift is shipped from Atlanta and costs $599.00 with $40.00 shipping.
I think a platform lift may be a better option at around $350.00 or $400.00
« Reply #13 on: January 19, 2011, 10:25:29 PM »
If I was going to buy one of the Harbor Freight ones, I'd get this one.......
http://www.harborfreight.com/1200-lb-capacity-air-motorcycle-lift-94813.html
Even though this one looks very similar to the Harbor Freight one, I think I like it better even though it's a little more expensive.  Still not a bad price considering all of the other lifts out there.....and it even comes with the side extenstions.......
http://www.derekweaver.com/update/Pro-Cycle_Droptail_XLT__Motorcycle_Lifts_Product.aspx?id=11
hotglue #43
« Reply #14 on: January 19, 2011, 10:38:57 PM »
The XLT droptail is the one I just got!!!!!!  ordered it from Derek Weaver on Thursday evening.. got it delivered Monday!!!!  fast service!!!!!
 blue=3 times
 green=at least 4 times
Gary
Northern New Mexico
« Reply #15 on: January 20, 2011, 05:56:16 AM »
Just curious,
I've been looking at the platform lift as well.
Question - does that front wheel chock or vice move out of the way once the lift is up if or as needed to get to that front tire for tire removal or front wheel access in general?
HG, what kind of freight cost did you get hit for since they had to use a lift gate?
Looks tempting!  Wink
« Reply #16 on: January 20, 2011, 09:15:00 AM »
Don't know.  But since hotglue just got one, maybe he can answer.
However, if you want unimpeded front wheel access, ya can't get much better than this......
http://www.derekweaver.com/update/MC615R_Air_Lift_Motorcycle_Lifts_Product.aspx?id=127
K&L Supply Co: MC615R Standard Air Lift (Motorcycle Lift)powered by Aeva
Or even better.....
http://www.derekweaver.com/update/MC625R_Air_Lift__Motorcycle_Lifts_Product.aspx?id=20
MC625R Motorcycle Liftpowered by Aeva
They're spendy, but if you want the best, I haven't found anything that tops those K&L lifts.
« Last Edit: January 20, 2011, 09:40:37 AM by BF » Logged
