Tropic traveler
Silver Springs, Florida
« on: January 21, 2011, 08:45:27 PM » |
After several failed attempts to find the right compromise of handlebar height, pullback & keep the throttle cables happy I may have hit it. I bought the $49.95 riser extensions from E-bay.   The cables are a bit snug at full LH lock but don't bind. The brass washers that you can see at the base of the risers probably will go, relaxing the cables a bit. After trying modified HD Duece risers & 4.5" aftermarket risers, both of which were too much & bound the cables I was happy to find a solution. Also installed a cheapie riders backrest also from Ebay for $43.33.  Not real heavy duty but it feels good, much better than none at all. Haven't gotten to ride it with the new additions yet because... you guessed it ANOTHER rear flat. This make SIX rear flats in the last 5 years.... 4 on my '97, 1 each on my Rocket 3 & the '99. First flat on the CT however. 60K+ riding miles & 5 flats, one every 12K average.  Oh well, gives me an excuse to put a bike tire back on. A new Avon is on the way!  Anyways, I plugged the CT & I'll take it out for a spin tomorrow. Maybe my quest to make the '99 as comfy as my '97 is finally nearing completion.
'13 F6B black-the real new Valkyrie Tourer '13 F6B red for Kim '97 Valkyrie Tourer r&w, OLDFRT's ride now! '98 Valkyrie Tourer burgundy & cream traded for Kim's F6B '05 SS 750 traded for Kim's F6B '99 Valkyrie black & silver Tourer, traded in on my F6B '05 Triumph R3 gone but not forgotten!
Ken Tarver
« Reply #1 on: January 22, 2011, 12:18:54 AM » |
REAR CT? I recently found 3 nails in mine, all the same size and type. Plugged 'em for a short while, then took the tire off and went and had inside patches put on.
Ken
Tropic traveler
« Reply #2 on: January 22, 2011, 08:55:36 AM » |
Ken
Yeah, I thought the same thing but being as I'm not completely satisfied with the CT I figured if it comes off the rim for any reason it isn't going back on. I would not hesitate for a second to patch any tire on my car or truck but the Valk aint a car or truck. I'm just skittish about any patched or plugged tire on a motorcycle. Anyways the '99 is aproaching 50,000 miles & since I don't know it's maintenence history I'm going to use this tire off opportunity to service the splines & driveshaft.
rrmdeuce
« Reply #3 on: January 22, 2011, 09:05:09 AM » |
How much rise do you get from these risers? Are they the standard 7/8" risers I see on ebay.
Chiefy
« Reply #4 on: January 22, 2011, 09:08:43 AM » |
I bought the same risers off eBay, and like them a lot. I have tendinitis in my right elbow, and carpal tunnel in my right wrist. Thought I would try an inexpensive riser to see if it helped. Elbow is fine, and wrist is a lot better, so I'm not going to buy any other riser. Backrest looks good
Ken Tarver
« Reply #5 on: January 22, 2011, 11:49:54 AM » |
rrmdeuce ~ if it says 7/8" it is for fitting a 7/8" handlebar, not 7/8" of additional rise, I was looking at the same thing......keep looking, I found the ones eventually for the 1" bars.....I'm thinking about doing the same instead of a complete new riser.
Ken
rrmdeuce
« Reply #6 on: January 22, 2011, 04:55:20 PM » |
Thanks for the heads up Ken. I'm the noob here. rrmdeuce ~ if it says 7/8" it is for fitting a 7/8" handlebar, not 7/8" of additional rise, I was looking at the same thing......keep looking, I found the ones eventually for the 1" bars.....I'm thinking about doing the same instead of a complete new riser.
Ken
ILcruiser
« Reply #7 on: January 22, 2011, 05:13:01 PM » |
Thanks for the tip; just ordered a set of the riser extensions.
1999 Valkyrie Standard
Hoosiervalk
« Reply #8 on: January 24, 2011, 03:27:25 PM » |
Hello everybody. I would like to try those risers on my 99 Interstate. does anybody have a item# for those on ebay? also besides placing the cables behind the forks, what other tricks does one need to know to add the risers? and I am 6' and about a 33 inseam would these help with the pain between the shoulder blades after about a 100 miles or so?
Ken Tarver
« Reply #9 on: January 24, 2011, 04:05:31 PM » |
Chiefy
« Reply #10 on: January 24, 2011, 04:11:03 PM » |
With 1 inch risers off eBay, you don't have to relocate the cables. No other tricks except that you should cover your tank with a blanket in case you bobble the handlebars when they're loose. A extra set of hands is nice to help you hold everything in place as you tighten things up. Only one way to know if they'll help your back. They helped the tendinitis in my elbow, and quieted down my Carpal tunnel a little.
Ken Tarver
« Reply #11 on: January 24, 2011, 04:14:08 PM » |
Hoosiervalk ~ don't think you will have to re-route cables
Ken
Tropic traveler
« Reply #12 on: January 24, 2011, 06:55:34 PM » |
Ken
Correct, at least on a Standard or Tourer you don't. That I have verified!
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #13 on: January 25, 2011, 01:29:15 AM » |
why don't you look at the xf6 website.... daryls 4 inch straight risers will do just what you want, plus they are new, and made right here in the good old usa by one of our members. also you won't have any problem with the cables.
Ken Tarver
« Reply #14 on: January 25, 2011, 08:34:51 AM » |
i ordered the extensions last night
Ken
Kingbee
VRCC# 576
Northern Illinois
« Reply #15 on: January 25, 2011, 08:57:46 AM » |
You won't have any problems with them on Interstates either. Been running them for a couple of years now
« Last Edit: January 25, 2011, 08:59:40 AM by Kingbee »
Baloo
« Reply #16 on: January 25, 2011, 09:29:29 AM » |
I am 6' and about a 33 inseam would these help with the pain between the shoulder blades after about a 100 miles or so? I had the same problem. I did replace the risers for the Phat risers and it helped. Another thing that made a big difference for me was the addition of a rider's backrest. It keeps my back from moving backward, eliminating the stress in my arms and between my shoulder blades. If you don't have one, you might want to try it.
Never ride any faster than your guardian angel can fly...
Tropic traveler
« Reply #18 on: January 30, 2011, 04:01:16 PM » |
How's it feel? Mo' better?  Don't give us no Bull!
« Reply #19 on: January 31, 2011, 10:53:20 AM » |
I think those extensions are a much better alternative.
There have been pics posted of the aftermarket risers that break right where the flange mates with the post.
Could be a very dangerous situation!
Hoosiervalk
« Reply #20 on: February 01, 2011, 11:23:39 AM » |
Ken those look great.and how do they feel? are those the ones off of ebay for about 50 bucks?
Ken Tarver
« Reply #21 on: February 04, 2011, 02:56:45 PM » |
yes they are the ones off ebay for about $50+shipping, I haven't ridden yet, been wet and cold here a lot, waiting for just a bit better weather, when I do will give a report in a new post.
Ken
Bone
« Reply #22 on: February 04, 2011, 03:23:52 PM » |
After seeing the pictures I ordered a set Tuesday. They arrived here this afternoon. Not bad getting everything approved and shipped from Ca. to Mi.
Randy3269
« Reply #23 on: April 02, 2012, 01:35:54 PM » |
Does anyone know if these risers are still available? The only ones I can find are for a Yamaha.
Tropic traveler
« Reply #24 on: April 02, 2012, 06:42:26 PM » |
Sellers name is puredrivecustoms, all small case letters. They are still there under his username in his "items for sale" link. Still $49.95 plus $8.95 shipping.
bassman
« Reply #25 on: April 02, 2012, 06:55:31 PM » |
Hey TT...have you considered a mud flap on the front fender? As I recall, long ago and far away, there were several on the board in the very beginning that were pretty confident a mud flap on the front fender would all but eliminate rear flats. Something about the front tire hits a nail/screw and somehow flips it back to the rear pointly side first. The flap is "supose" to eliminate that from happening. Can't prove or disprove the theory but a "search" back several years might provide some entertaining reading on the subject.
Good luck !
Tropic traveler
« Reply #26 on: April 02, 2012, 07:07:53 PM » |
I can officially bust the "front flap prevents rear flats" myth. Three of my six flats were WITH a front flap.
bassman
« Reply #27 on: April 03, 2012, 04:59:57 AM » |
Randy3269
« Reply #28 on: April 03, 2012, 11:02:49 AM » |
Sellers name is puredrivecustoms, all small case letters. They are still there under his username in his "items for sale" link. Still $49.95 plus $8.95 shipping.  Thanks!! They are on the way.
